Question about Hardware & Accessories
Cant get it to work
After setting the timer per the instructions, unit will not work
  • 5,245 Answers
1) Timer is not identified.
2) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/How-to-set-timers.html
3) Add comment Dec 2012 and describe timer in detail, and/or include photo of timer
Posted on Dec 12, 2012
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
Hello I need instructions on setting up the timer using the remote control for a RES 24C1 air conditioning unit. Hope you can help. thanks
There are 2 systems in timer set up. You follow as per your remote supports.
1. Set clock first. and then by pressing timer on make the time you need on. and same for off by timer off.
2. Press timer on which starts with 00.00. By pressing you can select how many hours after you want to switch on from current time and same for timer off. Is it useful? Write.
Dec 11, 2010 | Fujitsu 24C1 Air Conditioner
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
I am assumimg that when the plastic peg is pushed down the recirculater for the hot water is off. When up, it is on. The Build set the timer and no manual was left. Hot water comes onwhen it should be...
Do you have the auto-circ recirculation pump with timer?
If so, here is manual for that specific product:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Sep 29, 2010 | Hardware & Accessories
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
Need to purchase pins to place in the small daily timer of the ti
go to intermatic site
www.intermatic an search for irrigation timers. scroll to bottom of page and you'll see whats listed below
* Includes rain sensor input terminals- rain sensor not supplied.
** Includes 24 volt - 20 VA transformer.
For additional trippers (12 per pack), order No. 156T1950A.
For additional skipper pins (14 per pack), order No. 156T1954A.
Apr 04, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
43 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
