Question about HP Color LaserJet 2600n Printer
Hp laserjet P4510 ink smudging on the paper
I changed the cartridge out yesterday, thinking it would be the solution. However, when I am printing, the ink fades on another part of the paper. For example: on the top of the page, we print out a person's name with their address. In between paragraphs, the address lightly shows up. Does it need to be cleaned somehow? We use the printer every day and it doesn't look very professional with black smudge looking marks on the parts that have nothing typed on it. Thank you for your time reading this. Hopefully there is a solution to this problem. :) Erin
checkitright
  • 1362 Answers
SOURCE: hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Posted on Nov 08, 2007
Soulvisitor
  • 1113 Answers
SOURCE: HP 2600n prints black streaks on a page
Could be a few things but black cartridge is most common cause, they are not "cleanable" one just replaces them, if you carts are non gen HP then that will surely be your problem, slight chance could be transfer belt assy or fuser. they are also just a case of replacing, go for cart, replace it and see.
Posted on Dec 05, 2007
  • 137 Answers
SOURCE: black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Sep 16, 2008
  • 5 Answers
SOURCE: HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Posted on Nov 28, 2008
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Posted on Apr 05, 2009
How do I fix HP LaserJet P1606dn printing issue? it continues to print vertical line/ smudge on the far left of the printed document. Does anyone have any suggestion regarding this issue?
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Aug 05, 2015 | HP LaserJet Pro P1606DN Laser Printer with...
Smudge back of paper and will not print in color
User genuine print cartridge to avoid this types of issues.
>> Remove the print cartridge and gently clean it.
>> Check the smudge in paper feed area.
>> Clean the carriage.
>> reinsert the print cartridges
Try to print.
Dec 17, 2013 | HP Color LaserJet 3600
Smudged printing. Ink cartridge just replaced.
This is a laser printer and does not have a print head to be cleaned. Fortunately it does have a laser cartridge that can easily be replaced and solve all of your problems : ) The replacement cartridge is a HP Q2613A or the high capacity HP Q2613X. Your local Cartridge World should have a high quality refilled cartridge that will treat you very well and save you money.
Jan 03, 2010 | HP LaserJet 1300 Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Print out is dirty, there are smudges of inks at the page center
What colour are the smudges, if they are one colour you can try changing that colour toner cartridges. Failing this then it sounds as if you may need a new drum
Dec 09, 2008 | HP LaserJet 2550L Printer
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Sep 02, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
