Question about JVC RV-B90 Boombox
JVC RV-B70gy no power on. with cord or batteries.
Little fuses are ok on the power pcb . how to find fuse in transformer?thanx
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: model rv-b99 loses presets and does not power off
whenever I run into a memory issue with a portible unit that uses a battery backup I have found battery corrotion on the battery cointacts! also remove the main power source the batteries the wall plug and let it set for several minutes and hit the power switch a few times then retry everything again
Larry(techman)
Posted on May 14, 2010
budgie140
  • 501 Answers
SOURCE: KABOOM JVC Boom Box RV-NB10 when its plugged in
sounds like a dry joint in the power supply wiring inside,probably the printed circuit.easy to fix for an radio shop
Posted on Jul 03, 2010
gopakumarg43
  • 74383 Answers
SOURCE: have no power to my
Hello
If you have checked the power cord and found Ok, then check its two ends connected with the device, with a multimeter, ser in KOhms range, and see whether there is any continuity or not. If not either fuse inside it or its mains transformer is damaged. If found no continuity, open your set with care, and check the fuse first. You can locate it very near to the AC inlet of that device. In some JVC sets, a thermal fuse, built inside the mains transofrmer, is there, will gets opened, when the transformer overheats. It will be there between the primary and secondary windings, sandwiched inot the transformer and can be replaced. These are the possible causes that you described here; as no power is entering into the device.
Check these first. If you wants furthermore assistance, feel free to contact me through Fixya.
Ok.
Posted on Feb 22, 2011
dunnbiker
  • 8546 Answers
SOURCE: someone lost the power cord
There's probably nothing special about the original power cord, so I'd go to Radio Shack and get it for $8
http://www.radioshack.com/product/index.jsp?productId=3875429
Or you may have an unused one from other device lying around the house.
Posted on Mar 31, 2011
Will not turn on power lead ok and power to unit and fuse appears ok
There might well be a fuse. Look around the area where the power cord goes in and around the transformer.
Jan 27, 2016 | Panasonic Audio Players & Recorders
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
The radio works fine on batteries but not from the ac supply,whichunit checks out ok
Hi terry,
Try to check the power cord, it might be open due to frequent bending or pulling. If you confirmed that the power cord is ok then the trouble now is the ff :
1. Internal fuse
2. Thermal fuse of the transformer - If your transformer is open primary winding, check it inside the transformer. This is placed inside the paper insulator.
If you don't have an experienced in electronics then I've advice you to look for a qualified technician to isolate the problem.
Hope it may help you.
Have a nice day!
JDVillanueva
Feb 04, 2011 | Sony ICF-2010 AM/FM/SW Radio
There is nothing on the display,conditioner is death.The power is coming,fuse on the PCB is OK?
Check power to transformer (220volts---24/12volts Dc) which leads to function PCB. If 24 or 12 dc is o.k, then you have replace PCB only.If no output of DC, replace transformer. Thanks.
Jan 29, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
Does not start. The power cord, plug, etc., are O.K.
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 29, 2010 | Emerson MW8625W Microwave Oven
Power turns off randomly
Hello :
First check the power cord ! If it's OK , then you need to check if the fuses are OK also . If fuses are OK , then the problem is with the power PCB . Fuses are easy to be replaced . Power PCB is a bit complicated . You need to take your coffee maker to a repair shop for that .
good luck .
rate please !
Mar 19, 2010 | Keurig Elite B40 Coffee Maker
Nad c350 no power at all
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
Where is the fuse on a Philips FR 965 AV receiver
Hi Hibbs8829
Generally fuses are located on the PCB attached to the power transformer terminations. In some instances the only primary fuse may be a thermal fuse located inside the power transformer that may have failed. This one you cannot see from the outside. They are replaceable, but you will need to get into the transformer somewhat to sort it out. Other than that, there are often fusible resistors and circuit protector devices on the PCB. These can be a little difficult to find if you don't know what you are looking for. Good luck
regards
robotek
Jul 15, 2008 | Philips Audio Players & Recorders
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
JVC RV-B90 Boombox Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
