Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Error code C-B116, what does it mean?
Fellow associate was waiting for a print job, that was printed from his computer, and C-B116 popped on the screen askg to call the tech.
We don't have a tech, so I am asking you....
Thanks!
J.D.
  • 27 Answers
Code
B116
Description
Communication error with the fax board
An undefined communication error occurs between the controller and the fax board.
Remedy
1 Check the connector CN106 on MFPB for proper connection and correct as necessary.
2 Change FAXB.
3 Change MFPB.
That error means a problem with the FAX Board. Now, checking connections or re-seating connections of fax board to main board are advised first, then replacing fax board if that fails.
Posted on May 15, 2018
SOURCE:
  • 4 Answers
SOURCE: Bizhub C252
1. Touch the following code on the trouble code display screen.
Stop → 0 → 7 → 1 → 3 → 9
2. [*] will be displayed on the trouble code screen.
3. Touch [*].
4. The screen will be shifted to the data restoration screen to perform data restoration.
NOTE
• When the restoration is performed in a short time, data restoration screen may not
be displayed.
5. Check the message which indicates that the data restoration was successfully conducted.
Turn Main power OFF, and wait for ten seconds or more to turn it back ON.
Try this please and tell your tech support service to change job....
DaSoP from Greece!
Posted on Sep 11, 2008
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
patemi
  • 366 Answers
SOURCE: asking for file name before printing
Check and remove setting: "Print on fiile" in printer properties windows
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: WONT PRINT ANYTHING. DOESN'T LIST JOBS ON TOUCH
Is your cord hooked up to the back of the computer? It can have the power on, and everything, else but may be lose to the computer, worth checking.
Posted on Mar 17, 2009
SOURCE: print error page Bizhub C351
hello
I resolve the same problem by restart (power off power on) the switch with pluged Bizhub C360.
Maybe it will help someone.
Posted on Jan 11, 2010
After instructing the Print command in Word, Control Panel etc screened a window that said my Brother MFC-4800 printer was "printing the job" and immediately the job disappeared from the queue - but the...
Try to clear the printer spooler.
Try this instruction: https://www.online-tech-tips.com/computer-tips/how-to-forcefully-clear-all-jobs-from-a-print-queue/
Cheers !
Jan 02, 2018 | Office Equipment & Supplies
I've been using OKIDATE MICROLINE 320 PRINTER at work. I was printing something and I realized that I was printing the wrong page so to stop printing, I simply turned off the power and waited....
You would have to cancel the current print job from your computer for it to stop. Assuming you have access to a computer that is connected to that printer, you will have to find that printer by going to Control Panel > Printers and Faxes > Oki ML 320 then right click, select "See What's Printing" and cancel Current print job (I am also assuming you are using windows). I really hope this helps, if not add a comment clarifying your question, thanks.
May 23, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Samsung slp 770 incomplrte session by time out
The Samsung CLP 770 produces an 'incomplete session by time out' if you switch off the computer originating the print in the middle of the print job (before the print is finished) OR if the network connection is lost between the computer originating the print and the CLP 770.
The printer may have printed the start of the print job but also recognises that it has not received the end of the print job information. It waits for a good while for the connection to be restored in an attempt to receive the rest of the print job - but if nothing comes then it times out.
The reason for this action is to prevent this situation effectively locking out any other computer on the network from printing while it 'waits' for the end of the print job.
Dec 28, 2010 | Samsung CLP-770ND Laser Printer
The printer prints a test page everytime i turn the printer on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages!
(You may now reconnect the printer to your computer via the USB cable.)
COURTESY:LILBLUEMIFI- A FELLOW EXPERT
Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that would be changing settings used by the driver. Click ok.
Jan 26, 2010 | HP PSC 1510v All-In-One InkJet Printer
I have the lexmark x1270. When a prit job is cancelled, it does not fully cancel and I cannot print the next job. I tried to uninstall it, but I couldn't because a message keeps coming up to wait for the...
Check the bottom right side of the PC screen.
If you see the printer icon there, double click it. That opens the print queue.
Highlight the print job that is causing the failure and delete it.
Don
Dec 03, 2009 | Lexmark X1270 All-In-One InkJet Printer
Can't delete print jobs
If you are using a Windows platform then if you look at the bottom right of the screen you will see a printer icon. Double click on the icon and the print queue will be displayed. To cancel a print j0ob, highlight the job and then cancel it.
Don
Nov 18, 2009 | Dell 968 All-In-One Printer
How do I clear all of my current jobs, says printer is always busy? HELP!!!
The easiest way is to flush the print queue.
If you are using a Windows platform then when you look at the bottom right hand side of the screen you will see a small icon of a printer. Double click on the icon and then the print queue box will open.
In the window,you will see all the jobs that are waiting to be printed. You can highlight and then delete each job.
Be aware that there are other things that can cause a printer to "Busy" out. For example, an out of paper.
Don
Nov 17, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
7310 wont print
u have to clear the sent job, go to printers and faxes through your start menu, if u cant find it there, go to control panel, double click on the printer and faxes icon, on the pop up window, double click to open the printer then select all the jobs and empty the box, then you can start using again, make sure the printer is off while doing that.
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Bizhub C252
3. Touch [*].
NOTE
be displayed.
DaSoP from Greece!
Aug 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
4,509 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
