Question about Dishwashers
My top propeller fell off how do I put it back on my kenmore 665
    Problem Solver:
  • 16 Answers
It looks like you are missing one more part. There should be a small round cap like dish, that will fit on top of the perpeller to hold it in place, take a look in the dishwasher, posibly near the heat element to see if you can locate this part. The part should have a keyway to help put togeather correctly.
Posted on Dec 19, 2012
Kenmore model 665 top of door has pulled away from dishwasher
So.... Get some Bear Contact Cement in there. Let it set for 10 minutes then press the pulled away surface back into place and it should start holding.
Mar 03, 2015 | Kenmore Dishwashers
Kenmore model#665-17012402 clean light flashing,reset panel came back on does it require an element if so how do I remove.
Go to www.manualowl.com for free PDF, Bryan. Check the Index of the PDF for troubleshooting and perhaps you can put this issue to rest.Best wishes. Jimmy
Apr 11, 2012 | Kenmore Dishwashers
Kenmore refrigerator (model 106.58902802) ice dispenser mechanical linkage fell off (it looks like a rubber bell or pendulum). How do you put it back?
kenmore refrigerator (model 106.58902802) ice dispenser mechanical linkage fell off (it looks like a rubber bell or pendulum). How do you put it back?
Nov 13, 2010 | Refrigerators
I have a Kenmore top loading washer. While moving it into the house, it made a loud sound and a small copper pin fell out of the bottom. Does anyone know how to put this back in place?
That pin is a pin used to move the washer (secure the drum) and is not used when in normal operation. There are 4 total that should be removed. They are stored in little cups on the legs, and likely fell out of the cup.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 665-9580 error code ''E1 F2''
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Sep 30, 2009 | Kenmore Kitchen Ranges
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
Kenmore 70 series washer
check securing bolt on adgitator sometimes the bolt will strip out in main stem may need to tap out and fit new bolt
Mar 14, 2008 | Kenmore 22422 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
