Question about LaCie Bigger Disk (300874) 1 GB Hard Drive
Hard drive wont mount
Hi, I have had the hard drive for about a year... it works well.. suddenly today it wont mount it is running... plugged in... but when I turn on my system it gives me an error and tells me that the disk is unreadable... please help!... it has everything on there.... hope you can save me ben
  • 624 Answers
From the information you have supplied I would suspect either the drive data has become corrupted, a hardware problem has occurred or perhaps a problem with the LaCie software drivers installed on the computer. Be careful throughout this process, if you are prompted to format the drive you definitely don?t want to do that. I would first try a known good data cable in place of the one you?re currently using. If that doesn?t change anything I would try plugging another peripheral into the data port of the computer to make sure its working. If all that fails the next step to isolate what the problem is would be to try to connect it to another computer if you have that option. You didn?t mention if this was Windows or Mac but to minimize potential problems I would stay with the same operating system and version. When you plug the drive in the other computer it should recognize the new hardware and install the drivers. If all goes well at some point you should be able to open the drive and see your data. If that?s the case then there is a problem with the other computer, probably software drivers. If you get the same result on the other computer that would probably indicate the data on the drive has been corrupted in some fashion. What you do after that will depend on how much the lost data is worth to you and how much you are willing to spend to recover it. Let me know what you turn up, more info such as your operating system will help as well.
Posted on Jun 12, 2007
My xbox 360 wont work because i had it 3 years now, i put a game in doesn't work... i need help people...?
If it no longer works because you had it for 3 years, then you know the solution: Never keep an Xbox for longer than 2.9999 years.
If there's a hard drive inside, this could be seized due to lack of use. Grab the Xbox on opposite corners, and as violently as you can, rotate the case back and forth in the plane that the hard drive is mounted in. This action may loosen the drive's platters. I'm just guessing. Do lights come on when plugged in or does it look dead?
May 05, 2012 | Microsoft Xbox 360 Console
Hi all, My hard disk suddenly stop working, when
Try going to the control panel and then the install new hardware. When it asks for you to search for driver don't let the system look for a driver. Go to manual setup(or install from a list). If that doesn't work, then go to the seagate website to see if they have a driver for your version of windows. If seagate has the driver, then download it, go to install hardware, run the wizard, and when it asks for you to install from a disk that came with the device, click that option and the go to the directory where you downloaded the driver and load the driver.
Dec 19, 2010 | Seagate FreeAgent Go 320 GB USB 20 Hard...
When plugged in, icon doesn't appear on the desktop.
We have a few of these Lacie Design by F.A. Porsche 500GB drives in our office. Our editor's drive stop working this morning (was fine the day before) and had all her files backed up from the last three years on it and was making a very soft clicking sound. After taking the whole thing apart and trying drive in another F.A. Porsche caddy with no success, we tried a different power supply hey presto it started up no problems. My drive that suddenly stop working earlier in the year we tried a power supply from a external Lacie DVD Writer and again drive is working. Just to make sure tried the original power supply and would not mount. So if your hard drive stops working it maybe the power supply rather the the hard drive.
Jun 25, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Firelite hard drive won't mount on a Macbook
Sounds suspicious, have a look at other world computing, they have all sorts of work rounds for apple limitations. Have you looked in the disk utility to see if it is there? if so run repair and permissions.
Jan 25, 2009 | SmartDisk FireLite 80 GB Hard Drive
Can't Access to MioNet, Can't access to WD Drive
Hi to all,
I just saved my files from my WD world book that used to run on mionet... all of a sudden then disk couldn't be mounted and my files and all of my work just was there but not reachable...
so I un mounted the H.D.D. from the worldbook case and installed it over usb with an sata to usb adaptor (you can install it directly to your pc if you like)
then I searched the web and found and application-driver to mount ext2-ext3 partition on windows xp-vista...
and I started to see the "light" :)
all my files were there, untouched, unlocked.... so i took a backup and now I'm using the h.d.d. without the ethernet but via usb...
the software you need is here...
http://www.fs-driver.org/download.html
GREECE SAYS HEY!!!!
best regards.... ;)
Aug 21, 2008 | Western Digital 500GB My Book World...
500 gB doesn't respond to anything!
Leave it unplugged for a minute or so and see if it boots up.
Check the Power supply if it still works.
LaCie Bigger Disk (300874) 1 GB Hard Drive Logo
80 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
