Model PN51D450AZD
SOURCE: I have a D52GW12 tv.
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
SOURCE: after power surge aquos tv won't turn on
hi ther is a overload fuse on the psu board which will blow after a surge of power but to get to it you will have to take the back off
SOURCE: Tv won't power up after power went out
Most likely your TV's power supply was damaged with the power surge. You will need to take it to a repair place and have the supply checked out and find out the cost versus the value of the TV. I hope this helps.
