Question about HP Hewlett-Packard - LaserJet Pro M1217nfw MFP
Initializing Printer is stuck on initializing . I have tried everything but cannot remedy this error. Any help would be most gratefully received
  • 3 more comments
  • Stephen Dec 19, 2012
    Biff, Many thanks for taking the time to reply. I have tried as you suggested but without success. I held the buttons for over 2 mins and there was no change. Any other ideas please ?
    Best regards
  • Gaylord Cofie May 30, 2013
    Just did it works,follow the instructions carefully.
  • Omega15362
    Omega15362 Dec 05, 2013
    Biff if you were a girl i would kiss you, but since you are net I guess you will have to settle for a thank you.
  • dufresne lorinord
    dufresne lorinord Dec 12, 2013
    Biff you save my life, couldn't print all the exams for a primary school and i need thse exams as soon as possible . you save the kids . the printer is working now. thank you so much
  • Alex Lucas
    Alex Lucas Dec 18, 2013
    thank you sooooooooooo much
    New Friend:
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Posted on Dec 12, 2012
  • 5 more comments
  • Biff Boffo Dec 12, 2012
    Also, I would add, don't try the firmware updater again, it hosed my printer, too.
    Many thanks. I have tried this without success. Any other tips please ?
  • manuff66
    manuff66 Jan 25, 2013
    My printer is stuck on printing fax, then faxed received on monitor and then initializes. It won't stop! Done everything I can think of. Please help.
  • Linson
    Linson Jun 02, 2014
    thanks its working...
  • Haitam Attia
    Haitam Attia Jun 08, 2014
    what about hp laserjet pro 200 color m251n?
  • Wajid Hussain Jul 29, 2016
    Thank you so much my printer working now
  • HHCC
    HHCC Aug 13, 2016
    Had to hold down buttons for several minutes. Didn't work the first time either. But tried again with success, thanks!
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
Here is my fix for M1212nf.
Turn off the power and unplug the power case - always!!!
If you open the flatbed cover, you will see that the LIGHT bar is all the way at the end and it won't move back. Use STAR-shade screwdriver to remove screws around the rim. There are 2 screws under the plastic rim (different size). Lift the glass cover slightly and move the Light Bar to the middle. Close the glass cover and turn on the power.
If it works, turn the power off and put back all screws.
Posted on Oct 05, 2017
    New Friend:
This seems to be a major issue that HP needs to rectify before we throw these toys out. I am still stuck on the same "Initializing" issue on Laserjet M1212nf MFP ...
Posted on Jun 18, 2016
    New Friend:
How much did you keep the buttons pressed? For me ( hp laserjet pro mfp m176n ) it doesn't seem to work
Posted on Jun 29, 2015
  • HHCC
    HHCC Aug 13, 2016
    takes a couple of minutes, try again, worked for me on the second try
    New Friend:
Thank you very big Biff Boffo , My Printer got stuck on Initialization and i followed your steps and it worked well for my printer.
Posted on Jan 12, 2015
I've had my Epson for 2 years and it worked fine. I copied a document the other day, and it worked fine. Now when i attempt to print something from my pc, i receive a blank copy. I've attempted to...
Hi!
Try unplugging USB cable and replug it on a different USB port. Printer cannot initialize since there is connection issue between computer and printer.
HTH...
Dec 09, 2010 | Epson CX8400 All-In-One InkJet Printer
Unable to open printer(read error) this is the error message I have received. I have turned off the printer and the computer but the message is the same. I also deleted the printing job, turned everything...
try to remove printer from add printer wizard, unplug cable and insert, found new hardware must be appear, from that locate driver manually to initialize. restart pc and run test print wizard.
Mar 25, 2010 | Canon I960 InkJet Photo Printer
Canon Pixma MP500
Hello my friend, check if print head carriage has stuck and move the carriage a few times. You can also blew some compressed air around to clear any foreign objects.Also you can try moving the cartridge back and forth a few times and when you do that restart your printer .If still doesn't work you should take it to a repair shop.Good luck:)
Feb 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Carriage Jam error with HP C6280 All-In-One
I have tiis problem; the drive belt that moves the carriage came off.
Jul 19, 2009 | Office Equipment & Supplies
Error 30
I have the MFC 465CN - I was receiving two error codes:
Unable To Clean - Error 30
Unable to initialize
To fix, I first cleared the memory by unplugging the printer, then holding down the red stop/exit button, keep it held, power up the printer, and dont let up the button until it finishes the start up.
I then pressed the "ink" button and performed a cleaning, alignment, and quality check. After this, everything worked fine.
DO NOT try to print anything from your computer or have any pending print jobs while doing this - it appears that pending print jobs, or anything in the printers memory was interferring with the initilization and cleaning cycle it performs.
Hope this helps...
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
HP Deskjet F380 - NOT SCANNING
maybe this is one of those printers that need to be connected directly to the power mains, not a power strips..check on that first
http://tinyurl.com/6qcpgy
Jul 23, 2008 | HP DeskJet F380 All-In-One Printer
EPSON 9600
try to reset the settings in the printer panel inside the printer setup menu. try to choose the initialize all. then observe your printer operation.
manual for troubleshooting options OR check the manual here :
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14397&prodoid=19302859
Jul 06, 2008 | Epson Stylus Pro 9600 InkJet Printer
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP Hewlett-Packard - LaserJet Pro M1217nfw MFP Logo
15,715 people viewed this question
Seeker5211
Seeker5211
