Question about IBM Lexmark Personal Wheelwriter 2 Electric Typewriter 6781-018
Typewritter on but lights blinking on line size but the will not do anything. Is there a reset button somewhere?
  • IBM Master
  • 3,594 Answers
You probably need a keyboard. See my tip inder WW1000 or contact Geo. Beyers Co. for rebuild. They are very good and reasonable.
DickyO
Posted on Dec 12, 2012
My low tire pressure light stays on . Just had 4 brand new tires placed on my vehicle 2 weeks ago. Light still on.
Make sure there's 30 psi in each tire. If you have a full size spare, check that as well. If that's good, there should be a reset button under the steering wheel somewhere. Hold it down with the key on or engine running until it blinks 3 times and goes out. If that's no good make sure you still have 4 sensors.
Sep 04, 2010 | Toyota RAV4 Cars & Trucks
We bought the Gemmy Christmas tree trio last year. Just set it up today and the light show effects will not reset. Can't find the instruction manual
Press reset on the top of the main unit under the middle tree. The light will blink. While it's blinking, use a pin to press in the reset button on the back of the remote. The blinking light should go out, and you should be good to go. FWIW - I just looked for almost an hour before I found this answer today on-line. It worked for us.
Nov 27, 2009 | Gemmy Toys
Change font size on my bother ML 100
A typewritter is not like a computer. It is a mechanical device, that works by pressing an embossed letter in the daisy wheel through a inked tape into the paper.
The only way you can change either the font type or the font size is by buying and replacing the daisy wheel by another one with different font type/size letters.
To get to know more about your typewritter and accessories that might still be available to it, download Brother ML-100 Typewriter User's Manual
Click on "Go to View/Download Page" and in the new page click the "View/Download" button.
Look for page 16 (last page) of the manual for a list of cassette daisy wheels.
Aug 22, 2009 | Brother ML-100 Typewriter
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
The start light just blinks and the dishwasher wont start?
just found a web site that says crack door open, press normal, hot dry, normal, hot dry, then cancel to reset the controls.
Mar 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My PS3 turns on and plays the beginning music and displays the sony icon but then sits on the wavy line screen and I get no menu or anything
I had this same problem today. The solution was to reload the file format. To get to the screen that allows this, turn on the machine and remove any discs. Then press and hold the on/off button until it beeps twice. This puts the machine in sleep mode (red light on front). Now press and hold the on/off button until it beeps three times. Then a menu pops up that gives you several options. The one that worked for me was to reset the file format. It popped up and told me that the file format was bad and it was being fixed. It did this twice and then it started working again. Good luck.
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Miele g843scvi
Check the drain hose is clear and also the water feed is not kinked/blocked.
Then turn off all power, wait a few minutes then switch power back on.
Dec 10, 2007 | Miele 24 in. Incognito G843SCVi Built-In...
IBM Lexmark Personal Wheelwriter 2 Electric Typewriter 6781-018 Logo
94 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
