Question about Samsung 5.8 cu ft Freestanding Gas Range with True Convection FX710BGS
Error code SE on samsung fx710
While cooking the pannel will not work except for the clock which just blinks. I pressed to clear button and turned for the power for 2 minutes then turn the power back on. Only the clock blinks. After 10 minutes I got and SE code.
Just installed replacement glass top (from GE,original) and get Codes SE on the timer touchpoint.
That error comes from the touchpad, if it got wet, something boiled over on it, it is shorted etc.
May 07, 2016 | GE Profile 36" Electric Induction Cooktop...
What does 5AB mean on clock?
Your display is actually reading "SAB". This is an indication of a mode of operation rather than an error code. The following link explains:
http://www.fixya.com/support/r3608491-sabb_or_sab_explanation_kitchen_ranges
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features and operator, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 3 seconds to clear the Sabbath Mode. "Sab" will flash for about 5 seconds, then return to normal display.
Oct 22, 2015 | Amana 30" Self Cleaning Electric Range...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Electrical panel does not work
Hey John, this is JK. I understand that the display on your range is not working. You may have a faulty Electronic Oven Control (EOC). Please confirm there is power to the appliance. If there is no power verify that the power cord is properly attached to the unit, plugged into a dedicated outlet correctly, and that the circuit breaker/fuse is not tripped or blown. Also verify the power at the plug is correct. Is the time of day displayed when the clock button is pressed? Are you able to turn the clock OFF or ON? When the display is turned OFF the time of day will re-appear for a few seconds any time the pad is touched. To toggle the display ON or OFF, press and hold the CLOCK button until the control beeps once (about 15 seconds). If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Apr 07, 2014 | Frigidaire FPGS3085KF Professional 30"...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Samsung 5.8 cu ft Freestanding Gas Range with True Convection FX710BGS Logo
85 people viewed this question
Top Samsung Cooktops Experts
Lawrence Oravetz
Tom Chichester
Dave Lammas
Level 1 Expert
Are you a Samsung Cooktop Expert? Answer questions, earn points and help others
