Question about Honeywell Programmable Thermostat Heater
Turns on and then off and back on by itself
First the furnace turns on and about 10 seconds later turns off and then about 10 seconds later it turns on again. Why is it doing this?
  • 3 Answers
I have rebuilt many RHFE-551FA and RHFE-1001FA control circuit boards. If you would like more information about rates, turn around time, etc, please feel free to email me at fcg233@yahoo.com
Thanks!
Posted on Jan 13, 2009
2 Suggested Answers
  • 70 Answers
SOURCE: Turns on and Turns off
Does the furnace burners light? You could have a bad thermostat or a flame sensor. To check if it is thermostat turn power off to furnace take thermostat off wall take wires marked r & w and connect them together then turn power back on. If furnace comes on and stays on then you need a new themostat if not it is the flame sensor inside furnace. Also check furnace filter
Posted on Jan 16, 2009
My television does this thing now where you can turn it on and 10 seconds later it turns right back off again and when you go to turn it off from the power button it won't let you.
The horizontal output section to your TV has some shorted component/s. Check and replace them. Contact any experienced service technician.
Oct 14, 2012 | RCA TruFlat 27F520T 27" TV
I have central heat and air system, my problem is when in heat it runs for 10-15 min. turns off and about 20 seconds later starts back up. It shts off before hiting its tstat. temp.
If this is a gas furnace and you have a cooling coil on top then you could have a dirty coil. Also a dirty air filter can do this. I have also found dirty blower wheels. The gas furnaces have a high limit to prevent the heat exchanger from over heating. Another possibility is always a possibillity; however, 99% of the time I find an air flow issue.
Mar 24, 2011 | Bryant 463AAC008BA Air Conditioner
Thermostat calls for heat, purge motor turns on, 15 seconds later hot igniter turns on, then gas turns on and burners are lit. Problem is, they only stay lit for 5 seconds then shut off and cycle repeats...
,Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 02, 2011 | Goodman Heating & Cooling
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Apex pf2025 20 inch tv
timer set in menu options. Mine did the very same thing until I cleared the timer
Oct 13, 2007 | Apex Digital PF2025 20" TV
Treo 755 turns on and off by itself
Sometimes, your bluetooth device may poll (check) for your Treo 755. Also, if you have a data plan, you may have some type of program running in the background.
Sep 09, 2007 | Computers & Internet
Heating & Cooling Logo
280 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
