The is a line down the sceen - Computers & Internet
  • 27,725 Answers
Check the cables. It might be overly simplistic, but if your monitor is connected via a serial cable, one of the pins might be bent or missing. This can cause slight display problems, including a vertical line. If you are using a USB, try another cable and see if the problem persists. Update your video card driver. Some discrete cards have an update feature in the properties window for the device. Right-click on your video card in the programs list, and select "Properties." The update will be a button under the "Drivers" tab if your device is so equipped. If not, visit the manufacturer's website and search for the most current driver for your model number. Updated video drivers could solve the problem. Place a box fan directly behind your computers intake vent for extra cooling. Sometimes if there are system problems, your components can run too hot. If cooling the computer takes away the line, you know have you an overheating problem, not a monitor problem. You might try cleaning the internals with canned air. Remove the housing, and thoroughly blow any dust, hair or carpet fiber away from the fan and off the mother board. While you're there, you can check to see if there are any obvious loose connections. Connect the monitor to another computer if you have one available. This is probably the most definitive test of your monitor's health. If you have a line when the monitor is connected to a different machine, it's likely time for a new monitor. As frustrating as it sounds, taking apart one of today's monitors in an attempt to repair it is more expensive than buying a replacement. If you don't have another computer available, try shutting down the computer but leave the power on to the monitor. Using the buttons on the monitor bezel (if you have them), call up the settings. If the line appears in the menu just as it did in the video from your computer, then you definitely have a monitor problem. Replacement is probably in order Hope this helps.
Posted on Dec 12, 2012
Purlpe line down the middle of my vizio sceen
a number of possible reasons: bad connection from a board to display panel, a bad connection inside the display panel, a defective board that drives the screen and a number of other reasons none of which are easy to find or fix.
Aug 27, 2012 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Blue Screen, Zig Zag Squiggily lines, black sceen and freezes
No, try to call the HP tech support for possible repair. call at 1-800-474-6836
May 09, 2010 | Computers & Internet
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
Jan 14, 2009 | Singer Quantum XL-1000 Computerized Sewing...
TURN ON AND SCREEN IS BLACK W/ WHITE LINE IN MIDDLE
this might be the psp's problem you might of droped it .so go to a mechanic to help you pls. vote for me cloud_foe
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Jun 15, 2007 | Panasonic PT-47XD64 47" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
