Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
Beaters are hitting each other and jamming up
Will rotate and works with one but w both they get caught up together
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Posted on Jan 01, 2013
2 Suggested Answers
Loringh
  • 185 Answers
SOURCE: Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Posted on Nov 09, 2008
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
TURNED ON MIXER, BEATERS WOULD NOT ROTATE. ATTEMPTED TO REINSERT BEATERS TURNED ON AND MIXER STARTED TO SPARK. IS MIXER REPAIRABLE OR BETTER TO PURCHASE A NEW ONE?
You can try to replace the batteries again and see where that gets you.
As far as repair if the batteries don't work, I would recommend getting a new one.
Also check to see if it is still covered under the manufacturer's warranty period.
Good Luck
Jan 31, 2011 | Black & Decker MX55 PowerPro Hand Mixer
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
The beaters were clanging together. Now the
the gears were out of sync, by this time their probly stripped. IF you can get the gears, one must resemble a X and the other must resemble a + when installed, so they look like this X+ that way they wont hit.
Oct 17, 2009 | Black & Decker 220 Watts MX77...
2349 Stand Mixer - Beaters now hit each other
The beaters can be retimed but, you have to open the mixer. There are 2 gears visible inside the head. Look closely for arrows or dots on the gears. These are the timing marks. Like marks should be placed exactly opposite each other on the work gear. (The spiral shaped gear) Look at the notches where you put the beaters. One will be lined up straight, the other will be at 45 degrees. While you have it opened, you might want to regrease it. Remove the old grease with a stick or small narrow screwdriver. Put vaseline or equivalent in the gear area. Only fill it about half way. If you over fill it, it will leak out when you get it hot from long or heavy use.
Jan 02, 2009 | Sunbeam Heritage 2346 Stand Mixer
Good luck Loringh
Nov 08, 2008 | Sunbeam Heritage 2346 Stand Mixer
Replacement beaters
I had an SM100 which did not work when I got it out to make cookies recently. So, I have both bowls available (large and small), beaters, dough hooks, whisks and the use and care book too! I sure will miss that mixer. Contact me at lindareagan@comcast.net
May 29, 2008 | Black & Decker MX55 PowerPro Hand Mixer
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
391 people viewed this question
Top Sunbeam Food Mixers Experts
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
