Question about Frigidaire Dishwashers
Frigidaire dishwasher will only fill a little.
  • Official Brand Answer
  • 4,342 Answers
Hello Todd Thorley - Sounds like the dishwasher is experiencing a communication error with the control board or water valve issue. Technician will need to move forward accurately and either part will possibly need replacing.
Posted on Dec 14, 2012
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Will run thourgh cycles but only a little water will go in
Check fill line for a kink, (remove kick panel on bottom of dish washer)
If no kink then replace fill valve. Unplug dish washer fill valve is where water line is hooked on.
Aug 10, 2014 | Frigidaire Dishwashers
No water when running dishwasher
Good Morning Friend,
I understand that you are not receiving any water in your Frigidaire dishwasher. I also see that you have replaced the water fill valve. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause is, of your dishwasher not receiving water. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher fdb520rhs2 not washing
Hello - I will suggest verifying that there is enough water pressure coming into the unit. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Sep 26, 2012 | Frigidaire PLD4375RFC Dishwasher
Frigidaire dishwasher rinse aid seems clogged
Do a very hot water clean up with detergent.
May 14, 2012 | Frigidaire Dishwashers
Not washing
There are a couple of things to check:
Some of the first things to check would be, did the water accidentally get turned off to the dishwasher? You need a volt meter to check for voltage at the fill valve, then go from there. If you have voltage to the fill valve, than the valve is bad, provided you have water pressure to the dishwasher. If you do not have voltage to the fill valve, then the wiring needs to be traced back to the control board and check for voltage there. The overflow switch could be bad also. Also check the door switch(es). If there is a cancel/drain function, try that with the door closed. If it operates, then the door switch(es) should be good. Sure this would help: God Bless
Jul 08, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher not filling with water
look in the dishwasher theres a little float plastic and round take your hand and pick iu and drop it if that float stuck up when dishwaser had water,,it will need a little help dropping back in slot...onthejob
Jan 18, 2009 | Frigidaire Dishwashers
Dishwasher in not filling with water
Do you mean "no water" is coming in to the machine or just a little?
Sep 09, 2008 | Frigidaire Dishwashers
Dishwashers Logo
478 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
