Question about Stihl Garden
Will start but wont run. stihl 16in. chainsaw
    New Friend:
Try to clean the carb.
Posted on Feb 01, 2013
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
slohry
  • 87 Answers
SOURCE: Engine wont run.Stihl 028 chainsaw.
Remove and clean the exhaust port, muffler and spark arrestor screen. Also clean the air filter.
Posted on Apr 09, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
I need the bolt that holds chain brake handle on at bottom.
Try IS Engineers - you can find them on google. They are very helpful and will, if essential, send a parts diagram with part numbers so you can choose the part you need then order it online.
Sep 04, 2015 | Stihl MS 260 16IN Gas Chain Saw
Chainsaw wont stay running
if it starts (maybe idles) but then dies when giving it gas it sure looks like its a carb problem , most likely dirt in the high speed jet , but could be a dirty fuel filter as well and that's inside the fuel tank
Apr 16, 2015 | Stihl Garden
Stihl 015 chainsaw
Adjust the air/fuel mixture. Look at your owners manual or online because it gets a little tricky because of climate changes.
Aug 12, 2014 | Stihl Garden
My chain wont tighten on my stihl 044 chainsaw
Assuming you have the right length chain and its not just running out of adjustment, it would then probably be a stripped or snapped chain adjuster. Can be coursed when the bar nuts aren't dun up before starting to cut, the force of the chain saw will snap an adjuster no problems. If its striped it might smear like its adjusting in but when it gets to a point it will just stop
Nov 20, 2013 | Stihl 440 044 460 046 Chainsaw Clutch Drum
Stihl 038 super av starts hard, once started runs great till its warmed up then dies and wont start
check the seals on the crankshaft for a leak and the ignition module for a loss of spark as it warms up.
Dec 07, 2012 | Stihl 038av Case Buffers Caps / Plugs 2...
MY STIHL MS 290 CHAINSAW WONT START
Check your carburetor. You probably have a bad one and will need to replace it.
Oct 25, 2012 | Stihl Garden
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
Garden Logo
67 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
