Question about Samsung LNT3242H Television
The color on my Samsung LNT3242H LCD tv is very intense. The reds are really bright and so are the yellows and greens. I can't adjust them. Is this caused by a bad main board?
When TV first started doing this it would begin after the TV was on for a few minutes but now it is happening as soon as the TV is powered up.
Did you fix it? How?
I Have the same problem,,,
Posted on Feb 15, 2014
thecritter
  • 29 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Posted on Mar 30, 2008
SOURCE: Black/Dark Colors Fuzzy w/Red Pixel Outline
I have the same problem too....
Posted on Jun 19, 2008
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
SOURCE: connecting ipod to samsung lcd tv
how to connect I-pod to samsung lcd tv
Posted on Oct 16, 2009
  • 122 Answers
SOURCE: 40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Posted on Mar 09, 2010
SAMSUNG LCD 550 SERIES TV COLOR GREEN AND PURPLE
Sounds like t'Con board fault. Contact any service technician to make it confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Samsung Televison & Video
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
When we watch our insignia television anything red in color looks as if it is jumping or quivering...why is this?
This sounds like you are using a composite, S-Video, or RF cable input.
The quality of these inputs are not as capable as component or HDMI, so colors are not separated as well. Red is a color that saturates heavily and will cause bleed as well as dithering...especially intense colors (bright green, bright blue, bright yellow, bright red).
To reduce this visual annoyance you would need to soften the video output from the player (not easy to accomplish), or upgrade to a better cable connection.
Hope this helps!
Feb 14, 2010 | Insignia IS-LCDTV32 32 in. Television
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Televison & Video Logo
900 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
