Question about Intermatic Hardware & Accessories
Need a user manual in english for the Intermatic HB77R outdoor timer
  • Intermatic Master
  • 5,089 Answers
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB77
2) Timers are constantly changing as far east manufacturers take older design timers and reintroduce on market with almost-same features.
So the older manuals do not always work with new knock-off timer.
3) Add comment and describe timer in detail, and attach close-up photo of product buttons. Fixya downgrades your photo into blurry incomplete information, so be sure to start with close-up and in-focus photo. Otherwise images on fixya are frequently a source of miscommunication.
4) Post your foreign manual online, and send link. Expert can then use google-translate to roughly interpret manual into English.
5) Use google translate to help understand your manual.
6) Use your printer to scan foreign manual into a series of close up images, so writing is readable, and then attach photos one at a time.
Posted on Dec 12, 2012
arealplumber
  • 33 Answers
SOURCE: Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
Posted on Dec 10, 2008
  • 112 Answers
SOURCE: my rain tight intermatic outdoor timer no longer switches contact
the way the message reads the timer was working and then quit. most likely the contacts or clock motor has wore out. but by u sayiing u can't get power manually i would say the contacts or relay that switches the load is bad.
i would try to buy a timer that was the same and put the guts in the old box if its alot of trouble to change out.
one other thing u can check, is the timer getting its operating power from the circuit or is the something else controlling the timer. if there is something else controlling the timer, i would check that to see if i had power there.
Posted on Jan 13, 2009
VtToolMan
  • 704 Answers
SOURCE: intermatic outdoor can't reprogram. display reads NoOp
Les, First thing to do is to change the battery and see if the timer will allow you to reprogram it. Sometimes these timers will fail, as some models have a known history of failing fairly often.
NoOp, means non operating within the Intermatic line of electronic timers, so in order to see if the unit has failed or is just malfunctioning, due to a weak battery, remove the existing battery and install a fresh, new one.
You can remove the existing battery by flipping down the front switch panel and removing the battery tray with either your fingernail or a small flat bladed screwdriver. As your timer is showing the NoOp, you don't have to worry about losing your programmed on/off cycles, so you can take your time. Normally, if you're changing the battery, you get about 30 seconds to do this with some models of Intermatic timers, or you'll lose the settings. The newer models store the program regardless of how long it takes to change the battery.
Once you've replaced the battery, press the Reset button on the timer and allow it to refresh. If the NoOp is gone, just reprogram the timer with your on/off cycles and days and you're back in action. If the timer doesn't clear, you'll likely need to replace it, as it could be damaged and will not be able to be programmed again.
Usually, changing the battery and resetting the timer works about 60% of the time for me, as I've installed thousands of the various Intermatic timers in customer's homes over the years.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
  • 3 Answers
SOURCE: intermatic model HB77R timer
See the page link below, and once there, click instruction manual to see the whole thing. http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb77r.aspx
Posted on Nov 28, 2009
SOURCE: i can only find the
Intermatic posts manuals in Spanish and English, but not every manual is available.
Here are some choices.
1) Add a comment with timer model number and I'll find manual and post link if manual is available.
2) Go to Intermatic manual page below. Use 'Find' feature on browser (click Edit > Find) to locate model number quickly on page. Manual search takes you to individual manuals or to a product page. When page comes up model numbers show in a vertical row > click model number to view drop-down menu for links to manuals.
Not every manual is available.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
3) All else fails, use google translate. I re-wrote and posted GE yard stake manual today using translator. Enter whole sentences into translator > no need to translate word by word anymore.
http://translate.google.com/#auto'en'
Here's outdoor GE timer translated from Spanish using google translate:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
5) Add a comment and post link where you found Spanish version of manual (as long as it's not a free-manual-with-spyware website) and I'll locate English manual if possible -or- translate manual for you, and post result next day or so.
Posted on Dec 01, 2010
Intermatic HB77R Power Switch Problem
HB77R is discontinued timer.
If reset and battery change will not restore functionality, then replace timer with HB800RCH lifetime timer, or HB880R outdoor timers:
Gene
h
Nov 26, 2013 | Intermatic Programmable 7 Day Digital...
Need manual for HB77R
Intermatic HB77r outdoor raintight plug-in timer is for incandescent use up to 500watts.
Uses AA alkaline batteries. Batteries are for backup and don't affect timer operation in cold temps up to minus 40 degrees C, same as minus 40 degrees F.
Nov 15, 2010 | Intermatic Programmable 7 Day Digital...
Intermatic HB77R
Dec 09, 2008 | Intermatic Programmable 7 Day Digital...
Hardware & Accessories Logo
95 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
