Question about Brother LS-2125 Mechanical Sewing Machine
I have a Brothers 1500s. When I quilt with it the stiches skip every now an then leaving a large gap between stitches. Do I have the quilt to far up from the base of hte machine when I quilt? Should the upper tension be 3 or 4? Help. thanks.
  • Brother Master
  • 1,564 Answers
Your top tension is based on the fabric thickness.. not just a number. Make a test sandwich of all the materials you are quilting with, cotton top, batting, lining, etc. Test your tension on that until you get it right.
The skipping is a symptom of a bad needle or the presser foot not having enough pressure on it. I'm not familiar with your machine so I don't know if it has the ability to add more pressure to the presser foot.
Posted on Dec 12, 2012
SOURCE: Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
Posted on Aug 24, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 201 Answers
SOURCE: Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Posted on May 03, 2009
Mongo32
  • 111 Answers
SOURCE: my macine is new and i cant fix the bobbin tension
the problem is always on the other side of the fabric - if thread bunches up underneath, the top tension or threading is wrong
Posted on Jul 08, 2009
  • 1788 Answers
SOURCE: Suddenly my brother xl-2220 is
totally rethread, and do this test, rethread with the presser foot up, pull the thread it should feed smoothly, now lower the presser foot, pull thread, it should barely move. This will seat your thread in the tension discs, Also, don't be afraid to change your needle often.
Posted on Apr 26, 2011
Tl2000 and it is skipping stitches while quilting. I have changed the needle. I used needles 14 16 & 18 I have cleaned the machine. When I sew seams I have no problems.
Have you changed the type of needle--top stitch, embroidery, microtex? Sometimes that will help. Also, my skipped stitches occur in FMQ because the fabric is moving too fast for the machine speed or I have a jerky movement. It helps me to try slowing down the fabric movement or speed up the machine and practice making smooth, consistent movement. I've never done FMQ with a needle larger than an 80/12, so you might try a smaller needle to reduce the fabric grabbing the thread.
Skipping the Skipped Stitches in Your Free Motion Quilting
Skipping Stitches
FMQ Troubleshooting Tips Tricks
Oct 31, 2017 | Sewing Machines
Open-toe darning foot skips all stitches....help!
Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
https://www.superiorthreads.com/education/what-causes-skipped-stitches
https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
Feb 26, 2018 | Kenmore Sewing Machines
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Sewing machine skipping stitches and shredding thread
http://www.allbrands.com/products/15289-brother-pq1500sl-9-arm-straight-stitch-sewing-quil
Oct 03, 2017 | Brother Sewing Machines
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
122 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
