Question about LG LP6000ER Air Conditioner
Air gets warm and smells. No water coming out underneath.
Hi. we have the above air conditioner and cannot find out how to open the vents underneath to let the water out. What this air conditioner does is it starts off great, after a couple of hours it does not cool as much and after that there is a musty smell in the room. When we take the air conditioner out, it leaks water all over the floor. Also, it has a dry setting. What does this do? It does not mention this in the book we received with the air conditioner. I appreciate any help you can give us.
  • buxsingh Feb 07, 2009
    Hi My airconditioner works fine but if I have it working for over half an hour it drips water on the floor Can you solve this
  • 80 Answers
FIRST THERE IS NO SWITCH TO LET THE WATER OUT, THE WATER IS LET OUT OF THE EVAPORATOR SECTION THREW A SMALL HOLE LOCATED INSIDE THE BLOWER SECTION TO THE BOTTOM LEFT IT GOES THREW THE BED PLATE AND OUT THE BACK OF THE UNIT.MY GUESS IF YOU HAVE STANDING WATER IS THAT THE UNIT IS NOT PITCHED PROPPERLY IN THE OPENING. IT SHOULD BE PITCHED DOWN IN THE BACK AND SLIGHT RIGHT IF YOUR LOOKING AT THE FRONT OF THE UNIT. HOPE THIS HELPS.
PS THE DRY SETTING PROBABLY REFERS TO USING YOUR ELECTRIC HEAT STRIP AS A DEHUMIDIFIER TO RUN WHILE YOUR IN THE COOLING MODE BUT IM NOT SURE.
Posted on Jan 14, 2008
While on, air smells like mildew.
Is this a window unit?
I’m happy to help further over the phone at https://www.6ya.com/expert/david_66a56a0239b6ab32
Jul 28, 2015 | Haier CPN14XC9 Air Conditioner
I tried to run my air conditioner the other day, but the house started to smell like dust and dirt. If I pull the vent off and clean in there, how far back do I need to go to get all the dirt? I tri
Not all of your question was view-able, but sounds like your drain tube may be plugged if you are getting musty smells. Inspect the drain tube for clogging (lower right of unit). Pour a glass of water over the metal fins and watch to make sure it drains correctly down and out the tube. Look outside or at the far end where it drains and be sure water comes out. If not, try a bristle brush style pipe cleaner wire to insert and clean the opening. Once its draining well, you should use a mild bleach solution and spray bottle to hose down the entire inside heat exchanger. Never put anything into/between the metal fins except cleaning fluid. Using a brush on the fins will mostly just push the dust back and compact it so the water can't dislodge it. After a good cleaning, it will help to run just the fan or heat mode for a while so the vents dry before using cooling mode.
John
Jan 23, 2015 | GE Quiet-Aire Ductless Split System Air...
I have a strange situation going on in my house. When I turn on my airco frequently I get a nasty smell from the airco vents. Sometimes we have it running all day and it's fine (no smell at all) then at...
You should look in the air handler( Where the indoor blower is located) or in the plenum (where the duct system originate at the air handler) for any dead and rotting rats. Residential central air systems are sealed (uses circulated air only) and do not use outdoor air.
Aug 27, 2013 | Heating & Cooling
I canit open the door to change the filter
Hi -
Hello - Some air conditioner filters are removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well.
Oct 14, 2012 | Frigidaire FAX052P7 Compact Room Air...
How do I know if the vent is open or closed?
if it's the air vent you'll notice a different sound as well air pressure from inside to outside air. if it's the drain vent you'll see water flowing outside the unit. this is the condensation that forms
Jul 04, 2012 | Goldstar R8000 Air Conditioner
The air conditioning in my 2005 T&C stopped working. Right before it stopped there was a "burnt" smell coming through the vents. What happened?
No air coming from air conditioning vents
  1. Check the air conditioner fuse and replace as necessary.
  2. Air conditioner system discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  3. Air conditioner low pressure switch defective. Replace switch.
  4. Air conditioner fan resistor pack defective. Replace resistor pack.
  5. Loose connection, broken wiring or defective air conditioner relay in air conditioning electrical circuit. Repair wiring or replace relay as necessary. Air conditioner has a smell when used
    1. The air conditioner evaporator drain hose is blocked or partially restricted, allowing condensation to build up around the evaporator and drainage tray. Clear the drain hose where it exits the passenger compartment.
    2. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
Oct 10, 2010 | 2005 Chrysler Town & Country
The heater has a musty smell,I suspect i need to
It sounds to me if you are having a "musty smell" then you might have a problem with your condensation drain line for you a/c system or a small leak on your heater core. If it is plugged then water will collect in the vent system causing a musty smell from the water not draining and if there is a small leak on the heater core then coolant can collect in the vent system. I would run the a/c on a warm day and look for water draining from the vehicle around where the dash is located to check the drain line. As far as your air cabin filter most are located behind the glove box. You usually need to remove the glove box to get to the filter.
Dec 14, 2009 | 2001 Mazda Tribute
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
When our air conditioner comes on, it smells like the heat is on. This happens for a few seconds then goes away. However, it happens each time the a/c turns on.
This may due to teh fact that you may have the vent open and this is a common the air cpomes from outside in and get cooled and then passed to the room...make suer you have the vent closed.
Sep 08, 2009 | LG Heat cool Window Air Conditioner
Mold goodman phkj048-1
3 places where water could be coming from, The Ground, The venting system or the Condensate. Eliminate each one by first checking the condensate piping and check to make sure it is draining to the drain. Blow thru all hoses to make sure they are not blocked. Secondly, spray with a garden hose the venting system to see if the water is entering the system thru the venting. Lastly, if this happens only when it rains, you could have a ground water drainage issue.
Dec 26, 2007 | Goodman PHKJ048-1 Air Conditioner
LG LP6000ER Air Conditioner Logo
601 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
