Question about Neff U1721 Double circotherm Electric Oven
Element or thermostat - Neff U1721 cooker
I replaced the element a few months back on my Neff U1721. This sorted the problem out. Unfortunatly the problem has arisen again. Using my new found skills of element replacing i took it out and it looks physically ok (no evidence of it blowing). Rather than replacing it (at a cost of £30) i have thought that it might be the thermostat. Just prior to it failing to work the oven was fine and heated up (with dinner inside). When we came to get our 'cooked' food out the oven was warm but not hot. it has since not got anything other trhan cold (the fan is working fine). My questions are: If it is the thermostat, would the element simply get hot then cut out or not work at all? Does the fact that the element is not getting warm/hot at all indicate that it is the element? Would the element always have some signs of damage if it 'blew' ?
Any other advice on this matter gratefully received.
  • peterjessop Jan 13, 2009
    Thanks barcencoa, will have a look tomorrow and let you know how i get on.
  • peterjessop Jan 14, 2009
    barkencoa, You are a star. Thank you. Borrowed a meter and one of the element bars showed as an open circuit. Went and bought a new one and bobs your uncle!! Many thanks - i owe you a pint as you saved me a call out!
    Regards
    Pete J
  • Neff Master
  • 3,463 Answers
Hi there.
It is possible that the element in your oven is faulty again without there being any external evidence that it is so..
To be certain whether it is faulty or not , you really need to test it with a meter,preferably an anologue one with a audible beep to test for continuity.
What you need to do is disconnect the element, and with the meter probes touch the terminals of the element, if it is o/k then the meter will beep, no beep ,element open circuit.
If your meter does not have a beeper, then set it the ohms range, and again test across the element terminals, if it is o/k then the pointer will deflect all the way across, no deflection, element
faulty.
It is doubtful that it will be a faulty thermostat,if the temp indicator light shows, that shows the supply is getting to the element.
If no light , then yes, it could be stat, to test if it is working, switch oven on, and with the element reconnected, test for voltage with the meter set on 240 volt range,no reading, stat faulty or no power between stat and element.
This should help you sort out what has happened.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
My Neff Main Electric oven does not heat up, the fan is running, the thermostat light is lit and I have replaced the element. ???? One of your experts states that it could be the temp control or the High...
If the thermostat light is lit, then it cannot be the temp control, as this what is causing the light to work, indicating that the power is there . I f I were you, I would ascertain that you are getting a feed to the element.
If you are, then new element is faulty, if no feed then you need to trace the wires back to thermostat and work from there.
Jun 06, 2010 | Neff U1721 Double circotherm Electric Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Neff U1721 repeatedly trips RCD. Have replaced lower element 4 times in last 18 months am I likely to have an underlying earth fault, or are "cheap" elements more prone to failure
Sounds more like the power supplying the oven is at fault. Need to make sure that all power is correct from stove to box. Very unusual for that many elements to be going bad.
Feb 04, 2010 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Neff u1721fan oven element has been replaced 3 times in two months
is it the right voltage?is the new element screwed tight when fitted?they should last alot longer than that--Ire close bye.
Nov 26, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
1,090 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
