Computer wont connect to tv
The computer will not connect to tv using the HDMI cable
  • 46 Answers
Are you sure that the t.v is compatable? have you tried the correct keys which is Fn+F8 that will enable you to change screens
Posted on Dec 14, 2012
Arius
  • 446 Answers
SOURCE: help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Posted on Aug 09, 2008
SOURCE: HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Posted on Jan 09, 2009
tat4u
  • 520 Answers
SOURCE: connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Posted on Jan 29, 2009
  • 220 Answers
SOURCE: Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Posted on Jun 26, 2009
tmatrix540
  • 69 Answers
SOURCE: no sound connect my laptop to my TV using the HDMI
You will also have to get a sound cable which you will plug into the speaker bit of your laptop and the 2 rca connections into your tv they will be 1 red and 1 yellow
the cable is known as a Jack 2 rca audio cable
Posted on Dec 13, 2009
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
How can I connect computer to tv
Most newer TVs have a VGA connector on the back with the rest of the connectors. This is generally the easiest connector to use. You can get a VGA cable from a local computer store to connect between your computer video connection and the TV. If you have an old VGA monitor you are no longer using, you may find that the old VGA cable is removable - as they are on some monitors.
Alternatively, you can connect to an HDMI connector on your laptop / PC to the TV's HDMI connector (they should be labeled) using a standard HDMI cable if you have such a connection available. This is the preferred method if you have this connector available on both devices.
Third alternative option is if your computer (or TV) have a DVI connector. This connector can be adapted to HDMI. As an example, if your computer uses a DVI connector, and your TV has an HDMI connector on the back you could buy a DVI -> HDMI cable, or just use a HDMI cable with a HDMI -> DVI adapter on one end.
Once you have connected to the TV in one of the above methods, you then have to use the TV remote and change the 'input source' until you see your computer.
Side note: If you are using a laptop, make sure that your external connector is enabled - for Windows users, right click on the desktop and choose properties then Display. (Windows 8 users, choose screen resolution in the same location).
Feb 24, 2015 | Netflix
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
My hdmi connection wont stay on on my vior plasma 42 inch
You may have used Monster cables which can expand the plug in the TV.
Sorry, but you'll need to get a new input or use tape to hold it in.
Jun 12, 2010 | Toymax Viore 42 in. Plasma TV
Used hdmi on another tv, wont work at home
what kind of cable, is it RCA plug that wont work.
if your TV support HDMI Cable since use the cable for your connection of your PS3 console to your TV at home...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
