Question about AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI MPEG Divx Xvid HDD TV MEDIA PLAYER fr SD USB external hard drive
How to reset nbox - AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI MPEG Divx Xvid HDD TV MEDIA PLAYER fr SD USB external hard drive
My Nbox keeps on pausing and unpausing during a movie and wont stop. Any solution would be helpful thank's.
tis more then likely that its a codec prob or a virus in your hdd also what size is it hav had probs 1.5 tb hdd but 2tb works bloody grate.also the nbox seems to run better if it formatted to fat 32 ive noticed any way hope that helped ya
Feb 15, 2011 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
I have this nbox flash player i have installed it with a wrong firmware after the upgrade process my nbox menu is gone and the.. i cannot use it anymore what should i do?
you need to give a bit more detail m8 is there still a signal going to the tv if so try using sd card instead usb port otherwise it pretty much only gud for a ashtray sori
Feb 12, 2011 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
I pressed the hd option in the set up menu and the screen went blank and a message no signal came up. any suggestions
First please excuse my english...I had the same problem and manage to fix it. Just remember that nothing is broken, the problem is you dont see what you are doing. First unplug your nbox and remove sd card or usb disk. then folow thease step. 1-plug the unit and press power. It is not possible to know if the unite is on... 2-press enter 3-press the down arrow 7 times 4-press enter 5- press left arrow 6- press enter. if it dont work try again and again. You have to undo what you did and put the unite back on the good setings. good luck
Jan 02, 2011 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
Real Media Player media-player-HP2-B --syncronize audio and video....how do I upgrade firmware?
To those of you still looking for the Nbox firmware upgrade I FINALLY found it and its definitely worth it.
It adds media support, a cooler UI, files are now sorted alphabetically (thank god), and much more.
download it here: http://www.savemefromboredom.com/4images/index.php?template=nbox
Oct 23, 2010 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
Hi, I just pruchased an NBox RMVB HD Media player. I have tried playing movies from my Seagate 1TB hard drive thru the media player on my HD TV but it is unable to read my hard drive however I have played...
you could try formatting your hdd to fat32 also some times this media player has probs reading certain codecs and i also noticed that when a hdd is too full it does tend 2 play up a bit well they say for a hdd to run properly you got to have at leased 15% of free space also there is firmware upgrade out there for the tvd version of this player that works gr8 hope this helped you out ka kite
Oct 21, 2010 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
NBox HD Multi-Media Player i have one of thes players. What has happend is that it wont switch to ordinary pal or ntsc format. It only is recognising the pal composite, or hd or ntsc composite, it wont...
are you shore its not your tv cos it should. Go into settings and change it to pal then try your tv settings or format your hdd to fat32 will wait to see your reply hope this helps
Sep 13, 2010 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
Freeview box
After scanning the box should save the channel automatically. If the box does not save the preset after scanning channels, then it is probably faulty.
Some box has a pinhole reset button at the back, if you have this reset button keep it pressed with a pencil for 10 seconds to reset the freeview box.
If it does not work, the nbox is probably faulty.
With freeview you only pay for few scrambled channels, the most of them are free and do not need any additional fee.
Freeview is not available in all areas, check that you have freeview in your location, and that aerial is well connected to the box, otherwise not finding channels is normal.
Sep 05, 2008 | Televison & Video
Digi mbox
what are you trying to play music through? what out and is i t selected? are you useing protools and trying to get playback?
Mar 18, 2008 | Digidesign Mbox 2 Barebone
AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI MPEG Divx Xvid HDD TV MEDIA PLAYER fr SD USB external hard drive Logo
157 people viewed this question
Top AGPtek Televison & Video Experts
Electro Med Services...
Are you an AGPtek Televison and Video Expert? Answer questions, earn points and help others
