Question about Intuit QuickBooks Pro 2008: Windows
Vista 32 Lockup
Whenever I try to print, transfer jpgs or any files from my network or SD card, or play graphics intensive games, my computer locks up (can't do ctrl-alt-del or any mouse movement). I disable my Radeon 3850 graphics driver through Control Panel/Device Manager and everything works fine -- with the exception of lower graphics.
ATI tech support is of no benefit when trying to resolve this problem. I have had a complete system rebuild from Cyberpower PC along with changing my video cards from 2 radeon 2600s to 1 radeon 3850 and still have the problem. I have reinstalled Vista, updated all drivers (including BIOS and ATI Chipset), updated DX10, increased power supply from 500w to 800w, and replaced the memory sticks - no effect.
I have lived with this problem for a year now. I have an MSI K9A platinum motherboard with AMD6000+ Athlon.
  • 912mash Jan 25, 2009
    I do have the SP! installed. I'm going to try and reinstall Vista and the latest mfr. drivers.
  • 101 Answers
Microsoft has admitted in the introduction their was bugs in their video audio media. If you go to the Microsoft web site and download their service pack it will resolve this issue
Posted on Jan 25, 2009
Transfer pictures from sd card to files
First the pictures stored on your SD card are already files. There are many file types for graphic images I'm guessing you want to transfer the files on the SD card to your computer so you can work on them with Photoshop or other Photo Editor or maybe just print out hardcopy pictures. You will need a computer that comes equipped with a SD card reader slot. Then all you do is plug the card into the slot and the computer will treat it like another hard drive device and will assign a drive letter to it like E: or in my case J: At this point you can drag and drop the files on the SD card to folders on you PC. If you don't have a SD card reader slot then you will have to resort to other methods. Most modern digital cameras come with a special cable and proprietary software that will allow you to plug your camera directly into your PC through a USB port. My Canon SX 500 allows me to do this. This way you can transfer the pictures without having to remove the SD card from the camera.
Oct 07, 2014 | HP Pavilion L2335 23" LCD Monitor
My ati radeon graphics card cuts out after about 20 minutes of intensive graphic gameplay use. this is not 'hard' graphics such as wow but just with use on facebook games and yet it will run all day w
Do you have a system utility that will let you check the temperature of your graphics card and your CPU? If you do, check if the temperature is rising significantly while you play. (For a 32-bit Windows OS, a free option is SIW (Software information for Windows available here: www.gtopala.com/ )
The next question is which model card do you have? Does it have a fan? Check if your fan is running properly. (For some computer cases, you can add a slot cooling fan next to the video card or an extra side fan to bring down the temperature enough to play Facebook games.)
Next check that your power supply is not getting overloaded. Some power supplies are labeled with their maximum peak output wattage. So if your video card demands extra power when doing intensive gaming, the power supply may not keep up.
If there is a fan on the ATI card that is not spinning, then you probably should replace it. It's possible to remove the fan from the card and then peel off the seal. Then add a drop of a machine oil that has few contaminants. (I use sewing machine oil or fishing reel oil.) Then replace the thermal compound and reattch the fan to the card. However, I tend not to trust this fix to last. There are replacement VGA card fans but finding one to fit your card can be hard.
I hope this helps.
Nov 13, 2011 | Computers & Internet
What is the maximum size of SD card for a dsi?
The Nintendo DSi and Nintendo DSi XL are compatible with most SD Cards with the following specifications:
    Memory Capacity: Up to 32 GB (Gigabytes)
    Type: The Nintendo DSi and Nintendo DSi XL support standard SD cards as well as high-capacity SD cards (SDHC) up to 32 GB in size. This includes miniSD and microSD when used with their respective adapters
    Speed: SD Cards with a slow speed may experience slow transfer time when loading files, or may not work at all. Slow transfer times can also occur with SD Cards that have a great number of files on them.
Feb 20, 2011 | Video Game Consoles & Games
Whenever take picture 'memory card locked' message on the display
In case it uses the SD card, then there is a lock feature in the card. You will need to unlock the card so that it becomes read/write enabled. In lock position, it is read only, so you can read the files from it but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card. Sliding it up or down will unlock or lock the card. When the card is locked, you will not be able to transfer any audio tracks. Nor will you be able to play any copy protected files. We recommend you always keep the card unlocked.
sd%20card%20lock%20slider.jpgNOTE: We have found that on some cards, if the slider is even halfway towards the lock position, the card will be locked. Make sure that the slider is all the way to the UN-locked position.
Nov 19, 2009 | Samsung L200 Digital Camera
My computer freezes and locks up whenever playing strategy games
start ur pc in safe mode and restore ur windows and the scan ur pc with anti spyware
Sep 09, 2009 | Computers & Internet
I Can't Play Games With My Geforge MX400 64MB AGP!!!
Make sure you are installing the drivers for the right OS, for example XP and 64 bit XP, or Vista 32 and Vista 64 are different drivers. Go to nvidia.com and select drivers, and select the right card, OS, and version, and download the drivers directly from nvidia site.
Apr 03, 2009 | XFX GeForce4 MX440, (64 MB) Graphic Card
Graphics card
You can try running the game in another mode. I had a similar problem playing WOW but I fixed it.
Here's how.
1)Create a desktop shortcut of the exe file of the game.
2)Right click on the shortcut and click properties
3)In the target field you will see something like "C:/Program files/teamfortress/tfrotress.exe"
All you need to is click it and move the cursor to the end give a space and type -opengl. It would look something like this
C:/Program files/teamfortress/tfrotress.exe" -opengl
If it doesn't work try
C:/Program files/teamfortress/tfrotress.exe" -direct3D
One of these modes gotta work. My money would be on opengl. If it still doesn't run then try updating your graphics card driver and try again.
Hope this helps,
Sai.
Jan 13, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
I have a psp slim. Ive transfered music, photos, video clips etc to the memory card/psp before by way of usb cord(about a month or so ago was the last time i used it) Now when i try to transfer anything,...
you need to update your system software by connecting it wirelessly to a network.
make sure they are MP3 files and they are put in the right folders... via USB on XP your computer it is possibley k: drive?
put mp3s in the music file...regular audiofiles will not play,...depending on your system software WMP files may not player either.
or your SD card maybe corrupt try formating it?
Jul 24, 2008 | Video Game Consoles & Games
File Transfer
Use file explore option in Activesyn or just use a SD card reader to transfer music, pictures, etc. to the card. It's much faster & easier.
Sep 08, 2005 | HP iPAQ HX4705 Pocket PC
Intuit QuickBooks Pro 2008: Windows Logo
822 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
