Question about Samsung CLX 3160fn All-In-One Printer
Main motor locked - Samsung CLX 3160fn All-In-One Printer
Sc 440 ricoh 2045 Cod 440
Code 440 Description Main motor lock
A main motor lock signal is not detected within 2 seconds after the main motor turns on. Causes • Too much load on the drive mechanism • Main motor defective
May 17, 2015 | Ricoh Aficio Office Equipment & Supplies
I have a 150 hp Ingersoll rand aircompressor It is showing "Main motor overload. We have checked the motor and there is no issue with the motor. The computor has locked up and we can not clear the fau
Most faults on the main motor have to be cleared by resetting the main motor overload in the control panel first. Simply push the reset button the overload. Then reset the alarm on the controller. If the controller is locked up pull the main power disconnect for 15 to 20 minutes. Power the unit back up and try the process again. if no luck you will need to replace the controller and maybe the over load or aux contacts. If controller is truly locked your only option is to replace the controller.
Oct 20, 2014 | Ingersoll Rand Air Tools & Compressors
My Ricoh 2238c color copier has a SC440-01 error, what can I do?
Main motor error
The main motor starts or changes
speed. The lock signal does not
continue for 1 second within 3
seconds.
• The main motor starts. The lock
signal is detected and operation
proceeds normally. The lock
signal is interrupted for 1 second.
Causes:
• Defective main motor
• Too much load of the main motor drive
Nov 01, 2012 | Ricoh Aficio 2232C Color Copier
How do I fix L4-31 error code?
error L4 01
Main motor lock detection
Cause: Main motor unit abnormality
Improper connection or disconnection the main
motor and the harness.
Check connection of the main motor harness/connector.
Replace the main motor
Replace the MCU PWB
ciao Valerio
May 16, 2011 | Sharp AR-5316 Advanced Digital Imager...
My Ricoh 1018D is showing an sc500 error code. what could be wrong?
SC:500 Main motor lock
Symptom: A main motor lock signal is not detected for more than 7 consecutive
checks (700 ms) after the main motor starts to rotate, or the lock signal is not
detected for more than 7 consecutive checks during rotation after the last signal.
Possible Cause:
IMPORTANT: From my experience I tell you disassemble the image unit and check for worn gears. If not replace the main motor.
Feb 02, 2011 | Ricoh Aficio 2018 Copier
I have a problem RICOH Aficio 2018D A MULTIFUNCTIONAL DISPLAY ON ERROR I prevent my SC 500. How can I solve this problem?
SC 500 : Main motor lock
Symptom:
signal
Possible Cause:
mechanism
Sep 14, 2010 | Ricoh Aficio 2015 Copier
Error sc500 occured, Help solving?
sc 500 is main motor lock.it happens mainly 2 reasons .first main motor faulty. second main motor is not able to take the load that means a gear is jammed . paper jammed in fuser. developer locked up. you need a tech to look at it
Jan 10, 2010 | Ricoh Aficio 2016 All-In-One Laser Printer
Konica minolta d183 error code C0000
Main motor malfunction.Change the main motor and check the fusing unit.For reset turn OFF and ON the power switch,unpluged the cords and wait 10sec. pluged on and then ON the power switch.
Oct 22, 2009 | Office Equipment & Supplies
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
Samsung CLX 3160fn All-In-One Printer Logo
26 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
