Question about Mitsubishi WD-73827 73" HDTV DLP TV
Cloudy started to be cloudy along bottom 8 inches of picture then working up the sides 3 or 4 inches more noticeable when picture is a night seen
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Sounds like a issue or problem with the optical light engine in the set, it is of course the most expensive part.
Posted on Dec 12, 2012
  • shawn linkie Dec 13, 2012
    would that be the same for a wd73737 and would cleaning the optical light engine work
    wheres the best place to order parts
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Water not clear
cloudy water is mainly due to poor pool maintainence.
Your purchase of the salt water system only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals.
I use a good stabilizer to hold the chlorine level longer
I use a non foaming algecide once a week
I also use a water clarifying product once a week
Now on to the clouds :-)
cloudy water is because of not enough sanitizer mixwd with a crappy pump from intex
I do not know the size of your pool so I will just use mine to show you #'s
I have a 7000gl pool with a 2500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line is you should run your system 24/7 between generating and straight filtering
The only cure for less filtering is to get a sand filter with at least a 1 horse power pump to pump 4000gl and uphaving a sand filter helps trap more small particles than the cartridge filter.
I noticed the difference the first night I had my sand filter. It ran for 6 hours before me turning my pool light on and to my surprise I did not see as many particles passing my light as with the cartridge filter and the second night nothing Crystal clear.
Bottom line is intex pumps and so on are not big enough for the pool it comes with.
The salt system alone with a sand filter is great
Jun 26, 2010 | Intex Automatic Salt Water System for ...
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
I have a Kenmore side by side Model No. 363.9565522. Noticed water dripping out of front of freezer onto floor - this has happened periodically over the lifetime of the side by side. Slid bottom freezer...
The drain heater goes into the drain,not outside it.
You need a longer drain probe to push all the way through the drain.
Look underneath for a kink in the drain tube.
Feb 06, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
I want to build a telescope
go here for complete plans for a Dobsonian telescope.
www.raycash.us/sfsidewalk/intro.htm
go for the 8-inch. it's the perfect beginner's telescope.
you'll be able to see deep sky objects (DSO) like planets, galaxies, stars, etc.
the 6-inch is okay, but the 8-inch is better --> bigger is better.
with the 10- inch, you'll see more deep sky objects, but it's heavier and harder to transport.
the 8-inch telescope is a good compromise. you'll see more objects with an 8 inch than with a 6-inch.
also go here for a free star atlas
www.cloudynights.com/item.php?item_id=1052
go to the bottom of "cloudy nights" website for the Updated Version 2.0 star atlas
good luck with this project :D
Sep 08, 2009 | Optics
I have a Panasonic LCD projector ( PT-AE700U) - I have had it for 4 years. Recently, I noticed it was projecting "blue" pixels on the bottom right hand side (small size maybe 3 x 8 inches) . Over the past...
your color calibration may be off. see if you can set the red green and blue settings all to "0" and see if that works. may want to refer to your manual and see how you can do that and also see if there is a auto calibration
Jan 23, 2009 | Panasonic PT-AE700U Multimedia Projector
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
