Question about Sony CDP-CE375 5-Disc CD Changer
CD discs fell into the SONY CD changer. They're rattling around inside. What to do?
  • Sony Master
  • 1,267 Answers
Use common sense in removing them- You may have to open the unit up to see where they are. I can not see where they are located in your unit but usually opening the unit up will allow you to extract the discs without damage from the extraneous regions.
Posted on Dec 13, 2012
  • KitchenAid KBRP20ERSS Dec 13, 2012
    Thanks. I removed the cover--six screws--and retrieved them. Was concerned that taking the cover off the unit might disconnect something.
  • Sam Palermo
    Sam Palermo Dec 13, 2012
    No , the only thing you need to be careful of is staying away from the AC mains if the unit is still plugged in. Other than that there are not things that are booby trapped like some cable boxes.
fairlane
  • 50 Answers
SOURCE: sony megastorage 300 cd changer
Hi There are many things that can cause your problem, I can tell you the most likely ones, but I recommend you don't take the unit apart, as the mech. in a 300 disk changer is complicated & delicate, and you may just cost yourself alot more money than getting it repaired. The symptoms you sescribe can be caused by failing laser pickup, dirty laser lense (especially if you've done home renvations with drywall), split drive gear that moves the laser on the sled rails, or even a hair or piece of dirt in the gear teeth of that same gear. The unit will play fine, until it hits the tooth where the debris are, then it skips, or jumps back a bit and starts again until it hits the same spot. Also..badly scratched or finger printed disks will cause that, but that is the first thing most people check. I wish it was something you could repair yourself, but my best advise is to take it to a reputable repair shop, and hope it is not a bad laser, as that is a fairly expensive repair. Hope this helps, Good Luck!
Posted on May 04, 2007
SOURCE: Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Posted on May 18, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Posted on Mar 07, 2009
deejaykrish
  • 63 Answers
SOURCE: Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
Posted on Jan 17, 2010
Sony 5 cd changer disc exchange system With usb port
All this digital stuff can be more confusing for the user than standard tape systems. You may need to put files on the flash drive that are compatible with the CD changer for the files to be imported. Check the internet about this problem with the model unit you have and I bet you are not the only one having this problem. The flash drive may need to be having cda file son it or maybe something else.
Dec 15, 2012 | Sony CDP-CE375 5-Disc CD Changer
PLEASE HELP!! Sony CDX T69 CD Changer not recognised by my car.
I would inspect the harness to your unit and see if any wires are not connected..A fully connected harness ensures all functions are working as intended and if any wire that is supposed to be hooked up and isn't then there would be your issue..
Aug 21, 2017 | Sony CDX-T69 6-Disc CD Changer
Error-99 shows on screen then turn system off
Error 99 is CD not up to speed. Either the CD is slipping, Defective CD, pickup is unable to read sectors and is either dirty pickup or pickup going bad.
Is it always the same CD you are playing? Is the CD smudged with finger prints or dirty? If not suspect the CD itself. This will require Repair or Replace, as E-99 is a classic malfunction & unit will need to be taken apart, "unless" there is a CD stuck in the Unit.
If you have loaded a Blank Cartridge & clicked Eject & found no extra CD, then you will need to have a Reputable Shop Repair Typically this is the Logic I.C. & / or the Servo Motor. Sometimes you can find the same Unit on E-Bay, Craigs List, etc for less than Repair
Changer Error Codes:
E-00: Poor Cable connection.
E-01: Magazine not properly set in changer.
E-02: No Disc in magazine.
E-03: CD does not have selected track number.
E-04: Disc is dirty, upside down or unreadable.
E-10: No data is recorded on the MD. The player plays the next disc automatically.
E-99: Changer malfunction, disc may be caught in machine or changer requires service.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 26, 2011 | Sony CDX-454RF 10-Disc CD Changer
My Sony CD changer (CDX-454RF) won't play the first three slots, and I get error messages on other CD's and plays them when "it" wants to I guess
The changer has a mechanical slide system inside it. It may be binding up around those positions. You may want to take the cover off and reposition some of the excess grease into those slide tracks and try it again. Or you could just be happy with a functioning 7 CD changer.
Aug 05, 2009 | Sony CDX-454RF 10-Disc CD Changer
Hi there.
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Will one of these disc changers hook up to the new decks?
According to the manual at sony's web site, the sony cdx gt520 deck does indeed use RCA style hook up cables.
May 15, 2008 | Sony CDX-646 10-Disc CD Changer
Sony CDP-CE375 5-Disc CD Changer Logo
167 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
