Question about Akai LCT3285TA 32 in. LCD Television
Picture is frozen
I get sound; the channels change via the cable box. but the picture is frozen from a prior time. hence no picture, just a frozen image that remains the same. i unplugged my set and let it sit for 15-20 minutes; no change.
thank you in advance.
  • whayne_porte Jan 16, 2009
    What a joy. this gave me confidence and a path for the fix; after confirming the picture was good by playing a dvd though the player running through the ypo1 port, i unplugged everything and took the batteries out of the remote. I believe the freeeze button had frozen as i had tried pressing freeze before.
    It worked!!!!!!!!!!!!!!!!!
    thank you so very much for this conscientious and caring venue.
There is a button on the lower part of the remote that is a "freeze" button, it will freeze the picture, or capture a still shot. Try pressing this button to "unfreeze" your picture.
Posted on Jan 14, 2009
  • Patti Hardin Mar 06, 2013
    I tried that but it keeps freezing. Any other ideas?
Change from 2.0 to 5.0
Sounds like your Cable box audio settings are outputting two channels (stereo) instead of five channels (surround). It could be on an automatic setting, meaning whatever the digital audio stream coming from the TV channel is, your Bose system will play audio in that config. Hence why it changed from 5.0 to 2.0.
Go into your Cable box audio settings and change the output to Dolby Digital (or similar). You will also need to be connected via a digital optical cable from your cable box to your Bose 321 to output true digital audio.
If you post the make and model of your cable box I might be able to give you more direct instructions on how to do this if your still having trouble.
Oct 29, 2012 | Bose (321GS) System
Hi my sharp lcd tv when switch to DTV mode, the picture freezes however the sound still remains. I cannot change channels or go into any DTV menu options. Have you encountered this before?
It is probably not the TV , but coming from your signal source, cable box, or statile, and allot of times it is do to bad cabling, need to run new cable, RG60.
Jan 25, 2011 | Televison & Video
TV turns on, but a picture from previous channel I was watching is frozen to the screen. I've unplugged cable cable card and connection to cable service and picture is still frozen on screen. Will not...
sounds like a burn-in but are you saying that you can view another picture but no clear because the previous picture is still there. A burn-in is a tv being left on a fixed object like a picture and left there so long this is what you see when you change channels the image burned on the screen, is this what you have?
Jan 06, 2011 | Hitachi 42HDS69 42 in. Plasma Television
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
Channel numbers change but channel does not
The problem is in the "Guide-Plus" set-up. Go theu the set-up process again and when it asks you if you have a cable box select NO.
May 25, 2009 | RCA P61960 61" Rear Projection Television
SAMSUNG lcd tv
try resetting the cable box. If the tv menu does not cure the picture may be in need of repair.
Nov 11, 2008 | Televison & Video
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
Chang hold a picture
I think I already answered this question but here it is again. Your problem while watching cable tv sounds like a bad tuner with little or no adjacent channel rejection. The problem with the DVD and I think to some extent the cable sounds like a video processing problem. This unit has digital video circuits and could easily cause the problem you describe. The easiest and probably the cheapest solution would be to replace the board with a refurbed unit. Two companies which sell refurbed boards are PTS Electronics, Bloomington, IN (www.ptsinc.com) and Tri-State Module, Evansville, IN (www.tristatemodule.com). Good luck.
May 29, 2006 | Sony KV-32XBR450 32" TV
Akai LCT3285TA 32 in. LCD Television Logo
559 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
