Question about Linksys Wireless-G WUSB54G 802.11g/b
I recently installed a new wireless card in a gateway 320 laptop, it uses the Realtek RTL8185L chipset. I have installed drivers, but it keeps telling me that the wireless connection is not connected.
  • Ginger Zimmerman Jan 13, 2009
    windows xp
  • Peter Conway May 11, 2010
    If you have a network cable connect that and do the following:-
    Click Start --> (Settings) --> Control Panel --> Network Connections
    Double Click on Local Area Connection
    Click Support and check Default Gateway
    Open internet explorer and type http://
    then your default gateway address
    this will take you into your router
    Try finding Wireless settings and change the channel to a different one.
    If you cannot do this tell me which country you are in and the model of your router and I can help further
  • 258 Answers
Please let me know which Windows you are using and I wil gladly help you
HPC
Posted on Jan 13, 2009
Windows signed driver rtl8187b
Realtek RTL8187B page.
http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PFid=1&Level=6&Conn=5&ProdID=143
Realtek has placed it under RTL8185L drivers, and the links have a weird JAVA loop. Keep trying till it gives you the download. RTL8185_Auto Install Pargram _1.00.0145.zip
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PFid=1&Level=6&Conn=5&ProdID=143&DownTypeID=3&GetDown=false&Downloads=true
Oct 14, 2012 | Toshiba Realtek RTL8187B Wireless...
I have a gateway m-6750 notebook that i recently upgraded to win7 ultimate. for some reason my wireless adapter is no longer recognized and i cant find it anywhere
Hi
are y ou on your own laptop now
can you get onto the internet using a ethernet wire from your laptop into your router
if so have you tried all the windows updates
this may find and update the wireless driver for you
you could also try to un install it from your device manager
then re start the laptop
windows may on start up re install it correctly for you
have you looked on the official website for a windows 7 wireless driver
or you could look on the realtek website they may have a wireless driver for you
many thanks
Aug 19, 2011 | Gateway M-6750 PC Notebook
Can you tell me where the sodimm slots are located on a Advent 6551 laptop
Advent 6551 Laptop Specification CPU Intel Celeron Dual Core T1600 (1.66GHz) BIOS Phoenix BIOS. Press F2 to enter Chipset Intel GL40 Express Memory 1GB DDR2 PC2-6400 800MHz SODIMM (2 memory slots. Max 4GB) Hard Drive 160GB CD Drive DVD±RW Screen 17" Widescreen TFT (native resolution 1440x900) Video Card Integrated Intel GL40 Express Chipset Family Webcam Built in Sound Card Realtek ALC888 High Definition Audio Network Card Realtek 8139 / 810X (Onboard)
MSI MN54G 802.11bg Wireless G Mini PCI Card (MS-6877) Ports 1x Headphone
1x Line-in
1x Microphone
1x Expresscard slot
1x Card Reader
2x USB 2.0
1x Kensington Lock
1x LAN
1x eSATA *
1x DVI Battery U40-3S3700-B1Y1 (11.1v 3700mAh) Size 27.8 x 287 x 402mm (HxWxD) Weight 3.4kg Colour Black Made By F71IL1 * The eSATA port also doubles up as a 3rd USB port.
Drivers
Your laptop should have been supplied with a Utility CD which contains a copy of the user manual and all the drivers. There is also a copy of the drivers on the laptop itself, you can find it by browsing to the c:\applications\drivers folder. Finally you can download some of them from The Tech Guys website.
The Wireless LAN card uses a Ralink RT72 chipset so if you're struggling to find drivers then the "USB(RT257x/RT2671)" ones on the Ralink site should work - http://www.ralinktech.com/support.php.
Memory Upgrades This laptop has two memory slots. One slot is accessed by removing the cover underneath the laptop (see the "Bottom of Laptop" section below)
Jan 20, 2011 | Computers & Internet
I have a Gateway T-series (Model:W350A) laptop. I just reinstalled Windows Vista and now the computer is not recognizing the built in wireless card. How do I get it to recognize it? Or how do I install the...
Plug in an ethernet cable into your ethernet card port on the left hand side of your laptop. When it connects to the internet click on the Windows update icon in the system tray. It should show you a Realtek Wireless RTL8187b wireless adapter driver update. Install it, you may need to reboot, but in any case you will have wireless networks available to you and you can pull out the ethernet cable. Good luck.
Dec 30, 2009 | Gateway M305CRV Notebook
Reloaded the os on my gateway mx6436 and now it doesn't find the wireless card It was working earlier and the F2 function key shows it to be working
You have to install the driver for the LAN card, you should be able to get the driver from the gateway website driver and support
Nov 16, 2009 | Gateway MX6438 Notebook
I purchased HP pavilion DV6516tx model laptop in nov 2007,the configuration is intel core2duo processor,160GB hard disk,1GB ram,and the problem of my laptop is it takes minimum5 mins to start after...
Intel Chipset,(install and reboot before other drivers):
http://tinyurl.com/2vdz3e
Nvidia Graphics:
http://tinyurl.com/2q6ss4
Quick Launch:
http://tinyurl.com/2mk4tm
LAN 8101
http://www.intel.com/support/chipsets/sb/cs-011594.htm
Broadcom Wireless LAN Driver
http://tinyurl.com/35h4wn
Summer 2006 Original Realtek High Definition Audio Drivers
load UAA first (KB888111):
http://tinyurl.com/2p5u57
then
http://tinyurl.com/2g7gch
laptop homepage:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3446806&lc=en&cc=us&dlc=en&lang=en&cc=us
bluetooth
http://tinyurl.com/34pzk6
webcam
http://tinyurl.com/2lt8l6
and
http://tinyurl.com/y66eqj
another wireless if you have an Intel:
Intelâ® PRO/Wireless Drivers-Only for Windows* XP
http://tinyurl.com/ytyvjt
Spring 2005 Original TV Tuner Driver Collection
http://tinyurl.com/26aosx
Finger print driver:
http://tinyurl.com/2z7hgy
other HP supplied Drivers:
http://tinyurl.com/2sc4uz
Nvidia Graphics:
Realtek LAN
http://tinyurl.com/2yhcdl
Realtek HD Audio:
http://tinyurl.com/2flb6p
Motorola Modem:
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37811.exe
Some of the drivers below require .Net and Windows Installer 3.1
Windows Installer 3.1:
http://tinyurl.com/9cg2y
.Net Framework:
http://tinyurl.com/758p8
Use the drivers from dv9000t to fill any missing,such as Intel Pro Wireless,Ricoh Card Reader,Synaptics,HP Quick Launch buttons,Webcam.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3224058&lang=en
Nov 10, 2009 | Microsoft Windows XP Professional With...
Notebook does not connect to LAN or wireless
The dlinks have a tendency to reset to factory settings when you do a firmware upgrade. Connect to the router using a wired connection or using another computer, confirm the settings are what you want, not the defaults. NEVER use the default wireless name (in this case: dlink), always change it to something nobody around you is using!
Jul 25, 2009 | Acer Aspire 3680 Laptop
I have a hp pavilion a6631it and i don't have a driver i o instalato xp sul mio pc ma non suporta xp, o bisogni di driver.
Here the download link, this solution base on my blog post. you can read it here:http://laptop-driver.blogspot.com/2009/01/hp-pavilion-dv6631ca.html
Intel® 3, 900 Series Chipsets
DOWNLOAD
OR DOWNLOAD HERE
Intel X3100 onboard graphics:
DOWNLOAD
Audio,Realtek:
DOWNLOAD
NOTE:YOU MUST ACCEPT THE TERMS AND LICENSE AGREEMENT
Realtek ethernet:
DOWNLOAD
Motorola Modem:
DOWNLOAD
SM56_6.12.07_DFV.zip.
--ORIGINALSITE==http://www.motorola.com/Business/US-EN/Business+Product+and+Services/Software+and+Applications/Software+Solutions/Data+Communications+Software/SM56_Software_modem_US-EN
Youcan use drivers from dv6000t cto series to fill in missing drivers forIntel Pro Wireless,Synaptics,HP Quick Launch,Media CardReader,Lightscribe software,Bluetooth.
(No audio, graphics,chipset,from here)
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3224055&lang=en
OR
Use the drivers from dv9000t to fill any missing,such as Intel Pro Wireless,Ricoh Card Reader,Synaptics.
You will still be missing one driver for HP Quick Launch buttons.
It is QLB.zip,here:
http://www.mediafire.com/?c0jm93mbmdx
Additional driver, only necessay if our machine have them:
intel graphics:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289621&lc=en&cc=us&dlc=en&product=3642024&rule=41982&lang=en
If you have the Nvidia card option use this,recently recommended by another downgrader:
http://www.ngohq.com/home.php?page=nvidia
Theothers for Intel Pro Wireless,Synaptics,Webcam,Lightscribe,RicohCardreader,etc you can use from dv6000 page.(Only you know if you haveall the hardware that drivers are provided for.)
Hp Quick Launch link at HP is dead,use the QLB.zip I posted above.
If you have the Fingerprint device.
AuthenTec Inc. AES2501 Fingerprint Sensor:
sp35741.exe 1/1 (7.41M)
DOWNLOAD
FROM=(http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-49492-1&jumpid=reg_R1002_USEN)
Bioscrypt VeriSoft Access Manager,says for Vista but works on XP:
DOWNLOAD
Jan 26, 2009 | HP Pavilion dv2000t Notebook
Have realtek 8185, vista, keeps loosing signal
Go to the Device manager and bring up the properties to the realtek 8185 device. There is a tab called Power Management. Click on this tab. There is a checked checkbox that says Allow the computer to turn off this device to save power. Uncheck this box. This should stop the random disconnects.
Dec 02, 2007 | Adapters.com Genica Realtek A-8100 PCI...
Linksys Wireless-G WUSB54G 802.11g/b Logo
118 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
