Question about Hyundai Vehicle Parts & Accessories
Hyundai Getz misfiring
I have a 2006 Hyundai Getz. If I drive her steady she is all fine but if I have the revs below about 2000 or if I try to floor it, its almost like the car isnt firing properly by giving a few light jerks as it accelerates but as soon as I ease off or take it steady again it stops. Ive changed the spark plugs and leads but I have also heard that it could possibly be the air flow sensor. I have taken off and cleaned out all of the induction pipe and air flow pipes to the engine however I didnt come across the air flow sensor. Does anybody know if this can be the problem and if so where its located so I can possibly try cleaning or replacing it Thanks
    Problem Solver:
  • 12 Answers
Have you diagnosed the car for error codes? Upon reading your question I first thought about the HT leads anp plugs. You replaced those. Next step is to suspect dirty (clogged) fuel injectors. Pour a whole bottle of a good fuel injector fluid into almos empty fuel tank. Then add ONLY 2 gallons (8 liters) of fuel. Drive car around like "you stole it". Try to floor it or fully accelarate in 2nd gear as mech as you can, revvin ebgine above 4000 rpms.
If there was any dirt, varnish or clog in any injector, this procedure should fix it in a day or two.
Still do get an error code diagnosis as soon as possible. You may be surprised about what sometimes comes up.
Posted on Jul 19, 2014
  • Roberto Burgos S.
    Roberto Burgos S. Jul 19, 2014
    Have you diagnosed the car for error codes? Upon reading your question I first thought about the HT leads and plugs. You replaced those. Next step is to suspect dirty (clogged) fuel injectors. Pour a whole bottle of a good fuel injector fluid into almost empty fuel tank. Then add ONLY 2 gallons (8 liters) of fuel. Drive car around like "you stole it". Try to floor it or fully accelarate in 2nd gear as much as you can, revving engine above 4000 rpms.
5 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
mickha2
  • 145 Answers
SOURCE: I own a 1991 Opel
use a voltmeter to see difference in open close position (ohm)
Posted on Aug 16, 2010
bayyagg
  • 1672 Answers
SOURCE: I have a 1990 hyundai
Did you by any chance checked youre iGNiTiON COiL?
Posted on Nov 06, 2010
em1cl
  • 463 Answers
SOURCE: My 1996 Grand Voyager runs
You didn't mention any trouble codes. In 1996 all vehicles manufactured in the U.S were required to install the second generation OBD, also refered to as OBD II, to insure that a standard scanner could be used on all vehicles.
It shouldn't be a fuel problem with everything you've had done.
I don't believe it's an emissions problem, because, although emissions can cause a vehicle to stall it usually gives a bad idle and poor acceleration among other things.
Because you don't mention bad idle, loss of power, or no restart we can safely say it's not an emissions problem.
The only thing left that I can think of is an electrical short. I would start with having both ends of the auto shutdown relay checked for a good connection and have the contnuity checked.
Secondly, I would ant to have the wiring in the steering column checked for the same thing, in particular around the ignition. I am very sure your problem is electric.
I'm very sorry your having these issues and I hope this will help you solve them.
If you have other questions please feel free to leave me a comment, and I will get back to you ASAP.
Thanks, Donnie
Posted on Feb 22, 2011
pricedrive15
  • 16 Answers
SOURCE: where is the o2 sensor located on a 93 nissan altima 2.5L engine w/air?
one is in the front of the car, open the hood and look straight down the connection will be on the right side (driverside) the other is right at the flex pipe under the car pass the engine. yoiu may have to remove a heat sink to get to one in the front..for you stalling problem,,that may be fuel restriction, or TPS (Thottle Position Sensor) gone/going bad
Posted on Aug 01, 2012
My Hyundai Getz is pinging at a 3700 revs seems fine otherwise. Anyone know what it could be? Oil is fine and just had the power steering belt changed.
Bad gasoline or running an octane rating that is not meant for your engine will cause pinging. Out of time engines will ping too.
Jan 16, 2016 | Hyundai Cars & Trucks
Check engine light flashing on idle 2007 hyundai accent and sputtering. Previous (2 months ago) P0496 code caused steady check engine light. Some roughness noticed when accelerating steady below 60 km per...
Dont drive a car with the light flashing. A flashing check engine light means that something is really wrong and you can damage the engine if you drive it.
Nov 04, 2013 | 2006 Hyundai Accent
Hyundai Getz catalytic converter problems
i want buy used cataytic converter how much hyundai getz 1.3 2004 year
Dec 12, 2012 | 2006 Hyundai Getz
Torque settings for 1.4 hyundai getz , main bearings
I need torque settings on hundai getz 1.4 Mains and big ends
Oct 20, 2012 | 2006 Hyundai Getz 1.4
Hyundai Accent 2000 rattle in Steering Column
check the knuckle joint at bottom of steering column, its usually where it meets the floor before going through to steering rack. hope this helps
Feb 29, 2012 | 2000 Hyundai Accent
2006 Nissan Titan alternating misfiring and running fine until !
My truck is doing the exact same thing. I have been told it is the Intelligent Power Distribution Module or IPDM. The Nissan Dealership that is working on my truck says $400.00 parts and labor to fix.
Jul 19, 2010 | 2006 Nissan Titan
Getz 1300 hAas new cam belt fitted but now there
The tensioner is NOT spring loaded - it's adjusted by the technician who installed it. Take it back and tell them to FIX IT!
Oct 01, 2009 | Hyundai Motor 2004 Accent
Vehicle Parts & Accessories Logo
757 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
