Question about Confidence Power Plus Motorized Electric Treadmill
I have a confidence powerplus motorized teadmill. I need to replace the glass fuse in the circuit board, what size and rating should it be?
    Top Expert:
  • Confidence Master
  • 12,223 Answers
You must read the same fuse in the metal part, the specification, normally will be 15amp, 240VAC, However confirm with the indication printing specification in the same fuse, You can buy from R. schak or another electronic store.
God bless you
Posted on Dec 12, 2012
I have a 1993 Yamaha riva razz with a blown glass fuse. What size and amp glass fuse should i buy? Thanks!
Hi, Tristen for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://boards.straightdope.com/sdmb/showthread.php?t=385270
http://www.jacksscootershop.com/maintenance_tuneup_how_to.html
Yamaha SH50A Service Manual
OEM parts for Yamaha
http://joezekistan.com/documents/Yamaha_SH50_Razz_Owners_Manual.PDF
Apr 04, 2017 | Yamaha Motorcycles
Status light not on and wont staple
The most probable cause is a blown fuse on the circuit board. It is a cylindrical glass component with two chrome colored ends, located near the AC cord wires soldered to the circuit board. It can be checked with a volt-ohm meter, it should read minimal, close to zero ohms, across the ends. This fuse is soldered to the circuit board, mine is a 2A fast blow fuse with one lead attached to each end. If the fuse is OK or a replacement does not fix the problem, the bridge rectifier is probably bad as mine was. I rigged up 4 power diodes rated at 120 Volts AC and 2 Amps current as a replacement.
Apr 24, 2014 | Panasonic AS-302NN Electric Stapler Heavy...
My teadmill is coming on but the belt is not moving
1) LUBE THE deck belt inmediately
2) LUBE THE rollers bearing too.
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the diagram.
God bless you
Jul 21, 2012 | Exercise & Fitness
My haier tv model no. hl42e wont come on
Hello
If its power indicator LED at the front panel is also do not light up, there is some fault with its power regulator board inside it. Open your tV, and locate the power regulator board. It is easy to locate as, AC power goes direct to it after ON/OFF switch. Check the protector fuse [a glass cartridge type will be used] is burned out or not. If it ahs burned out, replace it with same type in both size and ampere capacity. You can not is rating on its rims; or it will be markde on the printed circuit board itself, under the fuse holder.
If the newly inserted fuse also blow out as soon as you switch ON the Tv, never use anymore fuses, as there is some direct short circuit with that power regulator board. It is better to replace that boad as card basis, than making any "surgery" to it. OK.
Oct 11, 2011 | Haier HL42E LCD TV
Wont power on
Hello
Open the TV and check its power supply board for any bulged capacitors or blown out fuse are there or not. If there is, replace it with same size and capacity. If fuse is found blown up, replace it with same rating. its ratings will be marked on it rims. These will be of glass cartridge types, and are pluged in types. They can be detached from its holder and can replace a new one. If the replaced new fuse also blow up as you switch on your TV, make sure that there is some short circuit with this board. Normally, power supply boards are very difficult to repair and make right. it is a best practice, to replace them as card basis. The board cabn be bought from most of the elctronic spare part shops at your town. I hereby attaches two pictures. One is not with your TVs, only to make you know how a bulged capacitor will look like. The second one is the picture of the power supply board of your Tv itself.
gopakumarg43_44.jpg See the bulged cpacitors [top side]; red arrow marked ones. A good one can be seen at the top right with flat top surcace.
gopakumarg43_45.jpg This is the power supply regulator board, your TV have. OK.
Sep 05, 2011 | Astar LTV-32ASB 32 in. LCD Television
Hi I have a wd640 hotpoint aquarius washer/dryer that has stopped working and been told by a fixya pro that it was the main circuit board,and so ordered this assuming it was the circuit board behind the...
hello there is usually a power board sits at the bottom if the machine is dead there a glass fuse that blows just replace the fuse make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
Motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Jul 06, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Jan 02, 2010 | Kitchen Appliances - Others
Hi there we have a la cimbali m30 dosatron and someone has pulled out all the fuses on the pc board and we need to know what sizes they are to replace them. Thanks Simon
There usually no fuses on a M30 dosatron unless it's the "L" shaped supplemental supply board which has a small 250V, 6 3/4 A fuse (half the size of a normal glass tube fuse). Most boards use a similar size but rated at 4 amps for the PC board power protection. The only other fuses (older models) have big 10 amp jobs for the main power to the heater elements. But this has been replace with safety relay and or high thermal limit breakers. you should be able to find both at a hardware store. The smaller fuses at Radio shack or electronic store.
Oct 21, 2009 | Espresso RMI La Cimbali Espresso Machine
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
Confidence Power Plus Motorized Electric Treadmill Logo
133 people viewed this question
Top Confidence Exercise & Fitness Experts
ray gallant
Electro Med Services...
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
