Does the pilot light go on?if there are no lights on,check plug,if your on a power bar,maybe you turned it off by accident,if it's new and none of the previous works ,run back to the store and RETURN IT
Press windows key + r key and type control panel and press enter Or click start windows button then type control panel under the search program of files then press enter.
Once your in control panel look for the display icon and click it, and on the left pane of the screen you can see there is a calibrate color click it. Simply click next button, click next button again, click next button again, click next button again, click next button again, click next button again, click next button again, click next button again, click next button again, now slide the red, blue and green color to the max settings. Then click finish button, after it will prompt your screen about clear type tuner, still just click next, next button to finish. Have a great day.
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
is it turning off or going into sleep mode? If turning off, you have issues with the power supply. look at it and see if any capacitors are bubbled up on the ends and replace if you see this.
Go to your computer's Control Panel, Power properties, and change the power scheme to Always On, where hard disk shutdown, monitor turn off and system suspend are all set to "never". This should help.
that happened to me. I felt stupid when I discovered what i did wrong. I attached the monitor cable to the connector at the top of the back of the computer(where it is supposed to attach, right?) - but, there was another connector for the monitor at the bottom of the computer which had been a special "card" add on. the monitor jack at the top did come with a plastic covering which meant not to use it. i thought the covering was just a protector, i didn't know. live and learn i guess.
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
