I was just given a pair of 40 year old Acoustic Reseach AR3a speakers. The hook up posts are labeled 1 and 2. Which is +, which - ?
  • kodomenico Jan 14, 2009
    Thanks, I'd pretty much assumed that to be the case, but it's good to have confirmation.
  • 1,175 Answers
1= +
2 = ( - )
Posted on Jan 14, 2009
I hooked Up my stereo receiver tuner to a CD player and am using 2 bose speakers Sat in a dry storage for 10 years After first hooking up sound was fine next time I turned it on speakers reverbatate I...
Foam rot, all old speakers get it, you can get them re-paired or buy a do it your self kit for 30 bucks, its happened to a few times, easy to repair and bose speakers are worth it usually
Sep 08, 2013 | Car Audio & Video
I have 1 speaker of Acoustic Research of 312 HO.
you have only one? or one pair? this standing speaker need a Amp to drive.
Apr 23, 2013 | Acoustic Research Audio Players &...
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
I have original AR3a speakers. Both speakers have T1 and 2 shorted with wire in the back, but still I am not getting sound on the tweeter and mid on both speakers? I got positive wire(red) on 1 and...
an ohmmeter wont help from the terminals as the mid and tweet will have capacitors in series and wont tell you ohms --the woofer can be read however and those are the bottom terminals --can you unscrew the crossover on the back and read ohms from there? traditionaly the blue wire is for the tweeter and the green is the mid ,ohm either to the black wire from where they first solder to the board--should be approx 6ohms each
Sep 04, 2010 | Acoustic Research AR3 Speaker
Speaker replacement
Any 4" mid with the same wattage rating will do
Jun 05, 2010 | Acoustic Research PL900SAT Speaker
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
Is there anyway to fix a blown Bose Speaker (201)?
The only 2 solutions are: 1. Just find an equivalent driver to replace. Re-wire new driver speakers into the enclosures. The old 201s may have had decent drivers (although probably paper cone) for back then, but now just about anything will sound as good in those particular cabinets.
2. Call Bose and exchange them for current 201 speakers (higher clarity more powerful). Bose will give you about 30-40% off I believe on a series 5 model. They now pay for inbound and outbound shipping as well.
Aug 12, 2009 | Bose Wave Radio II
Install Boston Acoustic speakers BA7800 to a new Imac?
Partial Solution anyway - I just got a Mac Pro (2.66 Nehalem )and couldn't find the manual from my old Gateway 700XL. This is what I did: Plug the green wire into the analog output, and the pink wire (if you really need an external mic, but you shouldn't since our new computers both have a built-in mic) into the analog input. Just ignore the black wire. You won't have the 2 surround speakers, but I'm still looking for a fix for that. I got tired of the crappy speakers in my new Apple Cinema display (the ONLY crappy thing about my new system). As you know, the sound from the BA7800 is great, even with just the two front speakers and sub-woofer. I'll keep you posted if/when I figure out how to set up the surround speakers! Likewise, if you hear something, please post here and I'll keep checking back.
Apr 10, 2009 | Boston Acoustics (BA7800) Computer...
Bose Acoustic Wave music system popping speaker
Had the same problem on the same machine 15 or so years ago...took it to the Bose factory shop in Framingham (or real close )Massachusetts, and they fixed it in 20 minutes...cost around $ the time they said it was a real common problem, and an easy fix.
Jan 20, 2009 | Bose Acoustic Wave music system II -...
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
