Manual for Midea MAE100 washing machine - Washing Machines
4 Suggested Answers
  • 6277 Answers
SOURCE: i need an instruction manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 14, 2011
caroldon
  • 17129 Answers
SOURCE: fault code E2 on midea
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 08, 2011
SOURCE: i have midea AW60 9906
LOOK AT THIS WEBSITE: http://www.midea.com.sg/support/manuals-guides,
Posted on Jul 06, 2012
MIDEA WASHING MACHINE INSTRUCTION MANUAL FOR MAE00-S2002GPS
Are you sure about the model number? I found an MAE100-S2002GPS washer on the Midea site. Go to http://www.midea.com/us/consumer/washing_machine/fully_auto/201404/t20140401_81499.shtml and click on the support tab for the manual. The direct link is http://img1.midea.com/us/Local_Library/info_instructions/washing_machine/fully_auto/201606/P020160614194954149229.pdf .
I hope this helps.
Sep 02, 2016 | Washing Machines
Hi I have a midea mqb80-700b 8 kg washing machine and sometimes it doesn't stop filling to the point of over flowing
Hi, you have to get your machine checked for the water sensor or water inlet valve as one is not working properly.
Dec 27, 2015 | Washing Machines
MIDEA AW70 509 WASHING MACHINE manual
Some manuals are here. If not similar to yours contact them direct.
Manuals Downloads
Dec 16, 2015 | Midea Heating & Cooling
Tear down instructions
follow outlet hose into mech its attached to pump
May 02, 2015 | Midea idea 1.6 cu.ft.Top Loading Wahing...
Midea instruction manual MAE70-S1402GPS
Haven't used the washer in a week. Tried using it today and this error code came up we unplugged it and replugged it like the Manuel said. The lids closed but it won't start. What could it be? It's only 7 months old.
Jul 19, 2014 | Midea 2.1 Cu. Ft. 6-Cycle Compact...
Leaking drum?
Is the filter cover fitted correctly?
Mar 07, 2014 | Midea Electric MAE70-S1402GPS 2.1...
Midea washing machine not spin/draining
The drain may have been clogged with something else.
Nov 25, 2013 | Washing Machines
I have a 5 year old Midea aw60-982 washing
Sounds like a bad belt or a locked up pump.
Sep 16, 2013 | Washing Machines
I have midea AW60 9906 top loaded washing machine and i lost its manual
If you type into your search engine 'midea aw60 manual' you should be presented with a number of sources from where you can either download free or pay. At some point you will be asked for the other number.
Hope this helps.
John C
Feb 07, 2011 | Washing Machines
Fails to start Midea dishwasher WQP12-9240AS
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Jan 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
