Question about Eclipse Car Audio & Video
Manual reset button AVN62D Eclipse - Eclipse Car Audio & Video
Where is the reset button on the avn 5435 Eclipse head unit?
After looking at the manual, there doesn't appear to be a reset button. If the unit is not turning on, try hitting the power button. A last resort option is to disconnect power from the unit by removing the unit from the dash and disconnecting the wiring harness that goes into the back of the unit.
Mar 01, 2011 | Car Audio & Video
I have a eclipse 4gb mp3 player with a blue screen reading "Eclipse" how can I reset this?
there will b small hole in player in that hole is actually for reseting device and there is small button inside that hole just press that button by small pin and you are done
Dec 26, 2010 | Mach Speed Eclipse 180SL 4GB MP4 ...
My 180SL 4GB Eclipse is frozen on the opening screen. How do I reset?
Same happened to me. I called the support number in the manual 580-272-0035, and they gave me the reason and the fix. The reason is improperly disconnecting the device from a USB port. This can cause the firmware to be corrupted. The solution is to allow the battery to completely drain, then before connecting to any power source, press the play button for 30 seconds. This resets the firmware. How to properly disconnect from a USB port is on page 17 of the manual and applies to any device.
Nov 07, 2010 | Mach Speed Eclipse 180SL 4GB MP4 ...
I had had an accident and my automaic fuel shut off kicked in where is te reset button located
there is usually a button located in the trunk. Check your owners manual for the exact location.
Jan 01, 2010 | 1999 Mitsubishi Eclipse
Where is the reset button on a 1994 Mitsubishi Eclipse
what is sort of reset?
there is no reset button.
maybe pull out the battery ( - Negative, black) then back it on. Reset done?
Jul 13, 2009 | 1995 Mitsubishi Eclipse
Eclipse 55430 User's Manual
Here's how to set the clock on the Eclipse 55430:
1. Press the [DISP] button repeatedly to switch to the clock adjustment mode.
2. To adjust the hour, press either button [1] or [2] while holding the [DISP] button down.
3. To adjust the minutes, press either button [3] or [4] while holding the [DISP] button down.
Hope this helps!
Aug 23, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
Jul 19, 2008 | Eclipse CD3422 CD Player
Eclipse cd3402
email me at memail0@yahoo.com i'll send you the manual I scanned into my computer as for the beep I believe all you have to do is press function then 6
Jan 30, 2008 | Eclipse CD3422 CD Player
Car Audio & Video Logo
215 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
