Question about Samsung DLP HL-P5663W 56" TV
Samsung HLR56 DLP has HD, DMI and sound but all SD is green with lines
At first, I had no video or audio. I pulled out the drawer on left with the RCA connections. There were two connections of wires glued in. I removed the glue and one connection did not appear to be completely seated so I pressed it in and it made a "click." I put it back in the TV and hooked up the cable. I got a perfect sound and picture ... as long as it was HD. Any SD station was green with lines or flashing boxes. Sound still good. I also hooked up HDMI to Roku and it shows fine. Any ideas?
    Sergeant:
  • 368 Answers
I have a Samsung HLR56 TV with the same problem. I am guessing the problem is the lower board you mentioned and am considering buying one so I can replace it. www.shopjimmy.com might have it so if I order it I will try it.
Posted on Jan 14, 2013
4 Suggested Answers
  • 98 Answers
SOURCE: Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Posted on Mar 05, 2009
gerrywilson3
  • 10 Answers
SOURCE: green vertical lines,minor. flashing goodback
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Posted on Jun 12, 2010
  • 7 Answers
SOURCE: yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Posted on Dec 23, 2010
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Whats the yellow wire
The yellow wire is for composite or rca phono type video connection.
Red and white are for stereo left and right audio. These are standart color codes to avoid confusion. Yellow is video. But these colored wires are all the same and can be used interchangeably if connected to their respected ins and outs.
Oct 29, 2013 | Pioneer Audio Players & Recorders
Connecting Laptop to a TV?
The TV inputs are as follows
Red and white RCA connectors is for left and right stereo audio
Yellow RCA connector is for composite video.
You need an adapter to convert 15pin video to RCA audio and composite video
This WEB site has this adapter.
www.amazon.com/Gino-S-Video-Composite-Adapter-Converter/dp/B0087ZB1E4
May 04, 2013 | Computers & Internet
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
How do you replace the electrical cord on a dd603
You would need to remove the lower drawer and the plastic cap on the mains filter board. The link below explains how to remove the lower drawer and access the main filter board.
The plastic cap is held down with small tabs, depress the tabs and slide the cover off. The power cord is screwed down to the mains filter.
Fisher Paykel Dishwasher Repair Video
Mar 24, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
I need to wire it to a tv but have only camera no adapter or wiring
Okay - from a google search placing the information
Lorex SG6153 into the text box came up with the web site below.
http://www.google.com/products/catalog?hl=en&q=Lorex+SG6153&um=1&ie=UTF-8&cid=3330978625885084760&ei=zLwIS5CQDZCINKyPlLoK&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CBkQ8wIwAw&os=tech-specs
Here it gave me the specs that you have:
RCA jack output for your Video output connection
RCA Jack for both Left and Right Audio outputs.
So you will need to have Auxillary video and audio inputs on your TV. Most Tv''s have RCA Video and Audio inputs - many so you can connect your VHS player into the TV.
So - If you go to a local Target, Wallmart or even better yet Radio Shack or Best Buy. You will be able to obtain/purchase RCA male connector to RCA male connector cables. Many of these places have them in all kinds of lenths 'most common is 6feet'.
Many of them have all three connector's/cables together.
Yellow end is for the video
Red end is for the Right Audio
White end is for the Left audio.
Hope this all makes sense?
Blessings,
A/V Media Guy
Nov 22, 2009 | Lorex SG6153 / Weather Resistant Mini...
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Picture but no sound through my s-video hook up.
S video is just video, you need to run two rca jacks to the left and right audio channel thet the s video is on. The only one that runs both audio and video is the HDMI, component is 5 wires, s is 3, as is the old shhool rca 2 audio 1 video, so if you want the best picture and sound use the HDMI, next step down is Component, 5 wires, 1red ,1blue, and one green, just for the video, then the right and left audio. Or an optical audio, but HDMI is what you want, one wire does it all
Jan 03, 2009 | HP Pavilion dv6000z Notebook
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Samsung DLP HL-P5663W 56" TV Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
