Question about 3M SV-497AJM Vacuum
Rainbow d3c beaterbar has low suction Vacuum itself has great suction
  • 75 Answers
Did you check the hose or the power nozzle it might have holes in it.
Posted on Jun 29, 2009
Henry hoover
That means you had too much hair in your beaterbar or that you had the vacuum set too low to the floor. The beaterbar stopped turning and the rubber belt was slipping creating friction and heating to the point of melting. When you vacuum check often that the powerhead (beaterbar) is moving. If the belt ever slips it stretches or melts in half and must be replaced.
If you were referring to the motor then there isn't much you can do but replace the motor.
Oct 17, 2013 | Vacuums
D3C RAINBOW VACUUM POWER CORD
if you mean you wont to replace the cord this video will show you
Jan 05, 2013 | Rainbow Technologies D4 Bagless Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow D3C electric Hose is broke
NO NO NO NO you have to get a new hose in this situation there is no other way around it. If you screw up just the littlest bit reattaching that hose a vacuum that uses water will QUICKLY let you know. Do yourself, your family, and your life insurance company a favor and buy a new hose.
Apr 10, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow Vacuum loss of suction
If it is not the Hepa filter, you can check it by removing it running machine and seeing if there is a difference. It is always good to have your unit serviced about every 5 - 8 years or so.
Mar 29, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Low suction
Is the water seal in place or missing? Another cause would be a bad motor, running at a slower speed will mean low suction. If it is a motor, then you would have to replace it. Is the suction low at machine without the hose, if it is ok then may be a clog in the hose.
Feb 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
It sounds fine but it is sucking very little
If the suction at the port that the hose hooks into has low suction, then most likely you have a problem with the motor. Some of these Rainbow motors sound ok running, but are running at a slower speed, thus reducing the suction and replacing the motor is the solution.
Dec 24, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow D3C Low suction
You might check the carbon brushes on the motor, it could be that the motor is not running fast enough, which would mean replacing the motor. With the hose off, do you have good suction where the motor goes into the vac? If it is good there, then either the powerhead isn't working or the hose is clogged.
Dec 09, 2007 | Vacuums
3M SV-497AJM Vacuum Logo
109 people viewed this question
Top 3M Vacuums Experts
JoeVacs
Are you a 3M Vacuum Expert? Answer questions, earn points and help others
