Question about Dell Inspiron 6400 Notebook
External Mike not working
Hi, When I try to plug in the external microphone to my Dell Inspiron 6400, it popup a window asking for either microphone or line-in or take no action.I tried by selecting both the options but still the mike is not able to recognize my voice.Please advice
    Problem Solver:
  • 8 Answers
Try this:
Double click on the volume icon on the system bar (lower righ corner, asuming you are using windows), this will display the volume controls. Now, click on Otions -> Properties and select "Record", MAYBE you will need to change the Mixing Device in order to do this, click on accept or ok and the volume panel now contains the recording volume controls, check the silence mark ys not checked for the mic, adjust your volume settings if needed. Good Luck!.
To get the original volume config, just do the same selecting the play option.
Posted on Jan 14, 2009
Where is the michrophone on del inspiron 6400?
Unfortunately the Dell Inspiron 6400 is not equipped with a built in microphone.
You can use an external microphone having a 3.5mm jack by connecting it to the microphone connector found on the right side of the laptop.
Hope to have helped you.
May 16, 2011 | Dell Inspiron 6400 Notebook
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
Dec 09, 2010 | Dell Inspiron 6400 Notebook
My laptop monitor goes dark
Hi there! Try this trick...
You can adjust the screen brightness within BIOS set up...
It works with Dell!!!
^_^
May 13, 2010 | Dell Inspiron 6400 Notebook
After plugging the external mic it will work only
The problem could have been caused due to power management settings. Go to Control Panel>Power options. Under power schemes change it to normal.
Click apply and OK . Then check if the MIC is working fine or not.
Thanks for using fixya
Proton
Mar 27, 2010 | Dell Inspiron 6400 Notebook
No sound on Dell Inspiron 6400
the speakers hav problems or the sound chipset on the mainboard must be replaced.
you can use an USB external sound card too.
Jul 25, 2009 | Dell Inspiron 6400 Notebook
External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Jun 02, 2009 | Dell Inspiron 9300 Notebook
I call people, I can hear them but they can't hear
The Inspiron 6000 has no Internal Microphone. You will need to get an external microphone
Feb 21, 2009 | Dell Inspiron 6400 Notebook
Microphone
the external mic must be unplugged for it to work and you need to reconfigure the internal mic if it doesn't work... there should be an option for this under start>settings>control panel> audio> microphone
Jun 16, 2008 | Dell Inspiron 6400 Notebook
Micro phone not working in my DELL Inspiron 6400
There is NO built in microphone with this laptop. You will need to purchase an external microphone and plug it into the mic in socket.
Aug 30, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
350 people viewed this question
Alun Cox
