Question about Razor E300 Scooter
WIRING DIAGRAM FOR RAZOR E300 - Razor E300 Scooter
Wont start razor e300
On my eZip 1000 scooter, in front of the battery pack, there is a compartment that houses the controller & assorted connectors & wiring. There is also a plastic housing that contains 2 fuses. Check, inspect & test the fuse(s) with an ohm meter for continuity. If all other components are functioning normally, it's probably the fuse(s) that need replacing. Hope this helps.
Oct 02, 2014 | Razor E300 Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
E300s razor
Note the charger doesn't turn itself off. It will only signal batteries are charged. You can overcharge these batteries by leaving them on the charger for too long. Suggested by retailer is two hours maximum.
Any case, Jackson Mack is correct on all counts there.
If the light is green on the charger, and the scooter still doesn't go, there might be some other issue besides the batteries themselves like loose wiring, fuse switch, etc.
Nov 12, 2013 | Razor E300s Electric Scooter With Seat
Is there a fuse inside the Razor E300 electric scooter and if so where is it located?
All electrical product have some kind of fuse or circuit protector. Should be either inline with the battery and be a blade type fuse (trace the wiring), or on the outside of the scooter near where you plug it in and it will be the festoon type. Check the blown fuse for the correct amperage replacement.
Oct 13, 2011 | Razor E300 Scooter
Need to have manuals e 300 razor scooter,need
http://www.razor.com/products/e300-electric-scooter.php
May 14, 2010 | Razor E300 Scooter
Razor E300 Scooter Logo
145 people viewed this question
Top Razor Toys Experts
Clif Roberts
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
