Marvel 61AR Compact Refrigerator Logo
Marvel DIP switch settings - Marvel 61AR Compact Refrigerator
1 Related Answer
Anonymous
  • Posted on Feb 04, 2009
SOURCE: Marvel 6BAR stopped cooling
I had the same issue after the unit was two weeks old. Marvel sent service people to service the unit, but they ultimately told me that the unit was not suppose to get any cooler because "of federal regulations" (I kid you not). I had to have an unaffiliated repair person remove the digital thermometer and put in a manual one. Now the unit cools well and I am pursuing Marvel for the $200 the service person charged me.
With me problem on konica minolta 7235 show error code f35-8
1. Turn OFF the SW2 (sub power).
2. While pressing the copy quantity setting button 2
and 5, turn ON the SW2 (sub power).
3. [Software DIP SW setting screen]
Select a DIP switch number.
Use the or key or numeric
keys.
To use numeric keys, press the DIP
switch number key at the left before
entering a DIP switch number.
select Dip 3 1 to 0 from 3 1 1
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
2answers
Can I program a 10 dip switch remote to replace an 8 dip switch remote?
You should be able to, 8 dip switches gives you 256 addresses, the 10 dip switches gives 2048 addresses, just leave switches 9 and 10 in the off position and set the switched the same.
2helpful
1helpful
2answers
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
2answers
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
11helpful
No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
1helpful
2answers
My light for my marvel wine fridge will not turn off?
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
2answers
The dip switches define the temp range. You have it set to the warmest. Try moving the next dip switch to move the range cooler.
Top Marvel Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
