Question about Lands Phones
Will doing a soft reset on my iphone erase my call logs?
  • 15,935 Answers
No, this just re-boots the O/S your info is stored in memory.
Posted on Jan 13, 2009
Help with how to reset iPhone 5s pass code?
You can reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
Dec 12, 2016 | Cell Phones
Tip
IPhone soft reset
When you use your iPhone, as timegoes on, you will notice that it develops a few operational errors like application or startup errors, sometimes the iPhone may freeze.
This happens as a result of the system files geting corrupted.
To solve this problem you can perform a system reset of your iPhone.
There are two methods of resetting your iPhone, there is a soft reset and a hard (factory) reset.
The soft reset will not erase all your data but it will erase your resent data, so it is important to back up your files before performing the soft reset.
After you have performed the backup, follow these procedures to perform an iPhone soft rese:
1. Bring up iTunes.
2. Connect your iPhone to the computer, ( let it come up in its loop ).
3. Press and hold the power button and the home key simultaneously.
4. Keep these pressed until the screen goes off, then release the power button but keep pressing the home key.
If it does not work the first time, repeat it. iTunes will eventually detect that there is a device in reset mode and ask if you want to reset, hit yes and hopefully you will be able to get out.
If this does not solve your problem, you will have to perform a factory (hard) reset, which we can look at in my next tip.
Thank you for using Fixya,
Kenneth.
on Apr 10, 2010 | Cell Phones
How do i disable the passcode on a iPhone 6 plus with IOS 10.0.2.
You can't unless you do a factory reset, this wipes the phones memory clean along with the password or code.
Oct 06, 2016 | Cell Phones
How to reset passcode
If Find My iPhone app is on, you can try to reset iPad passcode with iCloud Find My iPhone. The detailed steps are shown as below.
  3. Select your iPad from all the devices listed. Click Erase iPad to erase your iPad along with its passcode.
reset-passcode-oxaxc0rwhkhzilrwacqreyis-2-0.jpg After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPad without any passcode.
How to Reset Password on iPhone
Aug 17, 2016 | Apple Ipad I-pad
My brother gifted me an iPhone 4. I want to erase all the data contained. How I can do this?
You need to factory reset the iPhone. it is a simple process
Begin the process, if possible, by backing up the data on your iPhone 4. Do this by syncing the phone (each time you sync, it creates a backup). This lets you save all your data and settings to restore to the phone after the reset.
When that's done, locate the Settings app on your iPhone homescreen. If you've rearranged your apps, locate it wherever you put it. Tap the icon.
Scroll down to the General menu. Tap it.
Scroll all the way to the bottom to the Reset menu. Tap it.
On this screen, you'll be presented with a number of reset options, ranging from just resetting all the iPhone 4's settings to resetting its dictionary or homescreen layout. The factory reset option is Erase All Content and Settings. If you're sure you want to factory reset your iPhone 4, tap it.
You'll see a warning reminding you that you'll be erasing all music, other media, data, and settings if you do this. If that's not what you want to do, tap Cancel. Otherwise, tap Erase iPhone.
It will generally take a minute or two to factory reset the iPhone, but when the process is done, you'll have a brand-new, pristine iPhone ready for whatever your next step is.
May 24, 2012 | Apple iPhone 4 Black Smartphone
How do you delete recent contacts in the text messaging log
hi, you can tap Settings > General > Reset > Erase all Content and Settings first, if it doesn't work, you can try iPhone Data Eraser, which can delete recent contracts permanently on iPhone and easy to use. It helps me a lot.
Jan 13, 2011 | Samsung Rugby SGH-a837 Cell Phone
You tube is not working at all on my iphone 16gb
I would try to do a soft reset, this is where you hold down the power and home buttons at the same time until the iphone turns off then when the apple logo pops up you can release, this will not erase anything it will just clean up your memory so that your iphone runs quicker, I do this once or twice a week just to keep mine running fine.
May 13, 2010 | Apple iPhone Smartphone
Will doing that reset everything
Doing a soft reset will not delete your contacts. Do do a soft reset, simply push the square button and the power button long enough for the phone to power off, and then get to the apple screen.
A restore can be done through iTunes, and that will erase everything. Its a good idea to back up your phone prior to doing anything.
Aug 17, 2009 | Apple iPhone Smartphone
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
