Question about Panasonic Televison & Video
Can I install Web Browser App to my Panasonic TV TX-L32D25B fitted with a DY-WL10
The DY-WL10E-K is working ok with all the apps I have loaded. I have noticed that for some Panasonic TV's with Viera have a Web browser App. Is there one for my Viera TV (TX-L32D25B).
5 Suggested Answers
  • 354 Answers
SOURCE: i have a Panasonic Viera
Well it could be the sound amplifier or a cold solder joint on the sound amplifier , Does the remote have any effect? or the buttons on the front? It also could be the jack in the rear to the tuner is loose, the cable.
Posted on Jun 30, 2011
diodeic
  • 1622 Answers
SOURCE: My remote control doesn't work
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons . Once you have completed test with your camera you can use the remote.
That's it, I hope you got it going again
Posted on Aug 18, 2011
vinceisaac
  • 2432 Answers
SOURCE: hi mate i have a
hi good day welcome to fixya
lets verify first to narrow down where the problem came from, now when the indicator is flashing then doesn't steady to green that is mean their is something error detected by the main board that is why won't turn on. at this point you will need to apply trouble shooting so first you need to open the back cover of the tv unit to access the internal part make sure you have the proper tools and device. now turn the tv on then while the indicator is flashing you need to check the output voltage of power supply if all present the 5v stand by,5v switch,12v and 24v. then check the PS_ON voltage from the main board going to power supply if not available their is a problem with the processor. then at the same time you need to have a INV_ON voltage going to inverter ballast if also no voltage around 3.3v then it was confirmed you have bad processor. check also bad component at inverter ballast a shorted component will cause the main board to shut off. hope this will help just let me know if it works thanks for consulting the fixya.
Posted on Sep 02, 2011
  • 149 Answers
SOURCE: Gateway Code for:-Panasonic Viera 32" LCD-TV
codes-0154, 0179, 0451, 0463
Posted on Sep 27, 2011
My phone browser is working but notdownloading what i want to do
  • Install and Use a Different Web Browser: Don't use the built-in "Browser" app to browse the web. Instead, install a browser like Mozilla Firefox or Google Chrome from Google Play. Chrome only works on Android 4.0 and up, but Mozilla Firefox still works on Android 2.3 Gingerbread. These browsers include their own rendering engines, so they don't use the system's browser engine. They're also frequently updated via Google Play. You'll probably find these browsers faster than the built-in browser if you have an older device with older built-in browser code, anyway!
  • Avoid Browsing With Embedded Web Browsers: Just using a third-party browser won't fix everything, as you'll still be at risk if you use an embedded web browser in an app - these use the system's "WebView," which is vulnerable. Avoid browsing with embedded browsers if you have a vulnerable version of Android. Stick to a dedicated browser app like Firefox or Chrome.
Feb 27, 2016 | Cell Phones
How select an App on More Viera
Download the user manual and refer it.
May 31, 2012 | Panasonic TX-32LX80PA TV
Iam having trouble with my DY-WL10 connecting with my panasonic blu-ray player.
What is the problem?
Are you having problem finding the router you are trying to connect to?
Are you having problem connecting the player to a router in your flat?
you need to find the routers name SSID when you scan for the right signal.
Most of the time the SSID (routers name) and the web key (Routers security key) to your router is marked under the router.
you need to make sure that you have chosen the right router when you have scanned the signal to the Panasonic DYWL10 Wireless LAN Adapter. then the rest should be easy.
I hope it helps!!.
Jan 02, 2011 | Panasonic DYWL10 Wireless LAN Adapter for...
Help setting up Panasonic DY-WL10 wireless adapter to 2Wire gateway 2701HG-B?
go to on screen "setup"
select "network"
select "Network easy setting"
Select "wireless"
do the connection check
the 2wire modem should be detected by the DY WL10
Select the 2wire
select "open system"
select WEP encryption
enter the encryption key, or just "key" (it is the number in brackets somewhere on the 2wire). Do not enter the brackets.
follow further prompts. It is easy from here on (famous last words)
Aug 15, 2010 | Panasonic DYWL10 Wireless LAN Adapter for...
Televison & Video Logo
405 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
