Question about HP Laserjet P3015X Printer
Hp laserjet p3015 not printing
Any way to get it to still print even when ink is very low? It won't print at all but I know it still has ink. Thanks!
    Sergeant:
    Champion:
  • HP Expert
  • 345 Answers
The printer will have a message in the screen saying roughly how many pages are left in the toner cartridge if the toner is running low. Try printing a "configuration page" by pressing "ok", arrow down to "information", arrow down to " print configuration page", then press "ok". If this page prints you still have toner left.
Posted on Dec 12, 2012
  • 313 Answers
SOURCE: hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Posted on Mar 31, 2010
  • 3 Answers
SOURCE: hp laserjet p3015 pausing after 5 or so pages
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Posted on Aug 16, 2010
  • 3 Answers
SOURCE: hp color laserjet cm 1312 window 7 driver
It sounds like you downloaded the PCL Universal Driver. Try the full solution driver or the PostScript Universal Driver. Both allow color prints.
Posted on Oct 19, 2010
SOURCE: hp laserjet p3015 prints really dark. how can i
EconoMode This product has an EconoMode option for printing drafts of documents. Using EconoMode can use less toner and decrease the cost per page. However, using EconoMode can also reduce print quality. HP does not recommend full-time use of EconoMode. If EconoMode is used full-time, the toner supply might outlast the mechanical parts in the print cartridge. If print quality begins to degrade under these circumstances, you will need to install a new print cartridge, even if there is toner supply remaining in the cartridge. Enable or disable EconoMode in any of these ways:
  • At the product control panel, select the CONFIGURE DEVICE menu, and then select the PRINT QUALITY submenu. EconoMode is turned off by default.
  • In the embedded Web server, open the Settings tab and select the Configure Device option. Navigate to the Print Quality submenu.
  • In the HP Printer Utility for Macintosh, click Configuration Settings , and then click Economode & Toner Density .
  • In the Windows PCL printer driver, open the Paper/Quality tab, and select the EconoMode option.
Posted on Mar 08, 2011
Geekman
  • 32281 Answers
SOURCE: why hp laserjet p3015 not prints on both side?
According to the specification for this model - the duplex unit is an option.
Duplex print options - Manual (driver support provided)
You can download a user manual from this WEB site.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=3815797
Posted on May 26, 2011
LaserJet P3015. Why is it printing dark background?
Hi Boateng Samuel,
I would be happy to help you with your P3015. Although the enterprise printer models are out of my support scope, I was able to find you the appropriate document specific to print quality. Please use the following document to troubleshoot the issue:
HP LaserJet P3015 Printer Series Solving Print Quality Problems
Best of luck, I hope this helps.
I work on behalf of HP.
Jul 17, 2015 | HP Office Equipment & Supplies
How to clear error code 49.4c02 error on HP laserjet P3015
Cancell all print jobs in the print que.. shut down computer disconnect USB or Network cabes to printer... turn printer off then back on wait till printer comes to READY then reconnect USB or Network cables ... turn computer back on and print again
Apr 02, 2014 | HP LaserJet 4250n Printer
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
Oct 10, 2013 | HP Laserjet P3015X Printer
HP Laserjet P3015 fade
This could be because of few reasons, The Ink powder is not rotating inside the drum to give you the correct output.
Remove the Toner and Shake it a bit. Try to print.
Check for Firmware update available for your printer. There are Fixes released for known issues.
Click on the link below to find solution for all Print Quality related issues for your printer
HP Laserjet Print Quality Solution
Hop this Fixes the Issue
Regards,
Sean
Apr 22, 2013 | HP Laserjet P3015X Printer
Cartridge failed,
Typical HP Printer Problem. Usually if you could buy replacement parts (HP Stopped selling them for all HP inkjet Printers) you could fix this. My recommendation is to buy a new "$40.00-$50.00" low cost printer Lexmark, Epson etc. and when the ink runs out Throw it away and buy a new one when you need to print again. I found that the low dollar printers print, by way far, better pictures, graphics and everything else. If you print a lot of text then a LaserJet Printer is best value. you can replace the Toner Cartridge and get 3000 pages per Cartridge. Buy a HP Laserjet if you do. everything else is not as durable. Thanks, Keith
May 18, 2012 | HP PhotoSmart Office Equipment & Supplies
Hp laserjet p3015 prints really dark. how can i lighten it?
Mar 08, 2011 | HP Laserjet P3015X Printer
51.10 ERROR
i cant print my document my hp laserjet p3015 print display error message 51.10. please slove this imdy.
Dec 13, 2010 | HP P3015 Laser Printer
HP Laserjet P3015X Printer Logo
339 people viewed this question
Seeker5211
Seeker5211
