Question about Royal 29099S-CX HT700 770X Shredder with Mesh Basket & Credit Card Capability
Royal HT700x will not cut help
It make a sound like it's ready for cutting, reverse makes the same sound. When I try to insert paper; just that sound nothing is moving. HELP!!!!
Mine makes noise in both directions but is not cutting like it used to. So I took it apart tonight and found a stripped gear in the gear reducer train. The motor and some of the gears makes noise but then the connection to the cuttings is discontiuous. Now I need to try to find a spare part. This may be your problem.
Posted on Sep 06, 2007
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Aug 27, 2016 | Royal SP12MX 12 Sheets PP Security Plus...
My shredder will only work in reverse.
There must be a button on the shredder you need to push so it works forward, this button has 2 options: forward for shredding, and backward to push caught papers out of shredder.
Jul 07, 2014 | Cross Royal 7 HT700X Shredder
When trying to use the 160MX crosscut paper shredder, when you insert a piece of paper it starts to go in then stops. If you hit reverse the paper comes back and the edge is cut up. The motor sounds...
Try putting some "shredder" oil onto the cutting blades...they should be lubricated routinely and if they have never been oiled they just may be plugged up with paper dust and debris.
Feb 23, 2011 | Royal 160MX Shredder
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
It will not turn on
Do you have lights.?? Will it run in reverse.???
Unplug machine and try cleaning the "eyes" in the middle where you insert the paper. If none of these work you may have blown pcb inside...you can call Royal at 1-800-524-0799 for parts assistance and prices.
May 03, 2010 | Royal 29140X PX100MX Cross-Cut Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Royal 150MX bumping noise when paper is inserted
Sounds like you may have a gear problem; unplug unit open the top to see whats broken/stripped then call Royal at 1-800-524-0799 for parts and prices.
Apr 20, 2009 | Royal 150MX Cross-Cut Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Royal 29099S-CX HT700 770X Shredder with Mesh Basket & Credit Card Capability Logo
249 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Ed
Ed
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
