Question about Panasonic KX-TA824PK Phone
How to activate disa in KX-TEA308
At CO LINE MODE I selected disa for a line, in code 500 I selected with AA and in code 501 I selected appropriate jack no, but when incoming calls not happens no beep and system s=act as normal mode.
3 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: I have attached this cordless
If you start with intercom dial tone, press 81 or 82. If you dial 9 you'll get line 2 before line 1 in normal programming, and if you dial a line that's busy with 8x access codes, you'll get a busy, even if the other line is free.
Of course, you could also RTFM and program the system to function with your TA-824 http://public.carl.airpost.net/Pana/TA-824/UG_TA_0823%5B1%5D.pdf
Starting on page 15 or so of the pdf, after you set up the keys, you'd press the > and 1 or 2 to get to lines 1 or 2 :-)
Carl
Posted on Oct 08, 2010
Testimonial: "Just fantastic! Both the solutions were tried and worked!! I can't thank you enough.Have a great week-end."
cnavarro
  • 2460 Answers
SOURCE: we have Panasonic KX-T7731 telephones
A 3x7 system with 7731 phones tends to show that you have a TA-624/824 series system. CID is delivered to the phones via a xxx93 card and programming. In a 624 it connects to the main board via a ribbon cable and is installed in the system cover. The 82493 cards plug into slots on the main board. Once, or if, the card is installed, it needs to be turned on via programming. At the very minimum, program 900 in system programming turns it on and there are other parameters that you can adjust in the 900's.
Carl
Posted on Mar 16, 2011
How to active caller id for panasonic kx-t7730
It depends what telephone system the KX-T7730 is connected to. You should have a Panasonic box that says 'KX-TA624', 'KX-TEA308, 'KX-TES824' or similar somewhere.
Depending which Telephone System you have, it may just need programming or it may need an additional card (circuit board) installing. Panasonic KX TEA TES Telephone Systems Tiny Telecom
Nov 23, 2016 | Panasonic KX-T7730 Corded Phone
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
Which is yours?
Carl
Aug 28, 2011 | Panasonic KX-T7730 Corded Phone
What does a DICA card look like? I need to remove it so that callers do not have the choice to dial an extension, but instead it will go directly to our operator...
It's a DISA (Direct Inward System Access) card and you don't. All you have to do is just turn it off in software. In C.O. programs 414-416 or 3.1 in the Maintenance Console, you make sure that no lines are pointed to DISA and probably set to Normal and the system will ring normally.
Carl
May 16, 2011 | Panasonic KX-TA824PK Phone
I have a 824 ans just got a DISA card I need to program the DISA card Please advice if you can answer the following Question 1) How/what is the program code to record greeting message(msg 1 to 3) 2)...
My 824 has a DISA card already in it. What did the manual say? It has comprehensive instrucitons on how to use DISA and how to record the OGM. Try PROGRAM 911 from extension 101.
As far as the secondary greetings, I guess they would be in 912 and 913.
Activation and deactivation is part of ring assignment to trunks.
Carl
Jan 20, 2011 | Panasonic KX-TA824PK Phone
Hello friends from FIXYA, I have a situation where I cannot get my Panasonic KX-TA824 pbx to answer incoming call at the fist ring using DISA. I have tried everything and I cannot get it to work. DISA...
And??? What's the problem? My DISA is set for 1s on the first page and it never rings a phone. If you want it to answer the outside line on the first ring, you'll have to turn OFF Caller-ID. Now it will answer right after the first ring, but you lose CID logging.
On my working system, the DISA 6.1 section is with AA and 1 second, and 6.2 the first two timers are 3 and 5 seconds. In 9.1 you can uncheck CID but I don't recommend it.
Carl
Sep 22, 2010 | Panasonic KX-TA824PK Phone
Panasonic KX-T7730
With the handset still on the cradle press program and then the desired one-touch button. Now press 0 followed by the desired CO line example 1 or 2. Now press the Auto Dial / Store button to save the changes. Press program to exit programming mode.
Please rate if this answer was helpfull
Thank you
Feb 03, 2010 | Panasonic KX-T7730 Corded Phone
Programing outside (CO) line button
press program button then press the flexible where you want program the CO line then press 0, here u can select which CO line need to be program.
Ali
Sep 08, 2009 | Panasonic KX-T7730 Corded Phone
KX-TA824 Select idle CO line
No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
Carl
Jan 24, 2009 | Panasonic KX-TA824PK Phone
KX-T7730 programming manual
i have 10 extentions but my call ring to all extentions. but the ring to one extentions 101 only plz tell me
Aug 05, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TA824PK Phone Logo
104 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
