Question about Xerox WorkCentre M-24 Color Copier
WHEN I START A XEROX 5020 IT GIVE COD U6 - Xerox WorkCentre M-24 Color Copier
U6 xerox 5014
U6 Battery on main board
Aug 08, 2015 | Xerox Office Equipment & Supplies
How to reset NVM in xerox workcentre 5020
how to set xerox work center 5020 sound problem
Jul 11, 2012 | Xerox Office Equipment & Supplies
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Jan 15, 2011 | Office Equipment & Supplies
Xerox workcentre 518 gives U6 error whats the issue?
Press 0 button when U6 displayed; If it is U6-0, check control panel connection for proper contact; if U6-1, check paper tray pcb connection to mother pcb.... The paper tray pcb is located at rear side. open back cover and reconnect it.
Jan 05, 2011 | Xerox Office Equipment & Supplies
Mi copiadora IR 5020 se para y arroja cod E 0000020 y manda a apagar y encender el equipo que es este error
check the toner hopper maybe the toner is empty or the hopper motor is failed to fuction
Dec 03, 2010 | Canon imageRUNNER 5020 Copier
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
Apr 21, 2009 | Xerox 5100 Copier
Xerox work center c118
CRUM ASIC Failure
U6-6000 CRUM ASIC Failure RAP
The CRUM Control ASIC failed.
Initial Actions
Power OFF/ON
Procedure
Check the connection of each MCU PWB connector. The connectors are connected
correctly.
Connect the connectors.
Turn on the power again. U6-6 reoccurs.
End
Replace the MCU PWB (PL 9.1).
Mar 25, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre M-24 Color Copier Logo
140 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
