Philips livingcolors lamp stuck/freeze
After pluging in it suppose to run through all the colors then be ready for operating. Instead of that it starts immediatly to light only one color and it's non operational (remote was connected and working properly before this "stuck"). Any ideas how to 'hard reset' lamp?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Most of their sets do not have a reset for this kind of issue.
I will ask since you do not indicate this: have you tried to remove power from the set and any box if used for a while a then power back?
I assume from question you replaced the lamp, what was issue before you did that?
Posted on Dec 12, 2012
  • 2318 Answers
SOURCE: Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Posted on Jul 16, 2008
Ecollier2012
  • 3459 Answers
SOURCE: bad color
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
  • 610 Answers
SOURCE: picture turns black and white and freezes
if image freezes,dmd board or the main board has failed.
Posted on Oct 29, 2009
SD Tech
  • 14553 Answers
SOURCE: Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Posted on Nov 24, 2009
milkburp
  • 416 Answers
SOURCE: Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
Posted on Mar 18, 2010
DLP Projector BX327-JD lamp cover broke. Need a new cover
you can pick up some plastics instead of it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 14, 2014 | LG BX327 DLP 3D Ready Projector, Digital...
Philips light 69143/60/48 I can't remember how to auto cycle using the remote control
0) the lamp should be off
1) turn it on with the remote
2) swipe a full circle around the remote
3) press "on" again
Now it should smoothly transition around its color spectrum
Sep 30, 2013 | Philips 818564 LivingColors Mini...
Is oil light suppose to come on before starting bike just changed oil and filter theres 3 holes in window for oil
When You Turn The Switch To The On Position. The Oil Light Should Be On This Basicly Shows That Bulb Is Good. When Engine Starts And Is Running The Light Should Go Out Immediatly Indicating Oil Pressure.If The Light Does Not Go Out Shut Engine Off Immediatly And Investigate.OIL Level , SENDING UNIT, Loose Wire At SENDING UNIT.
Mar 17, 2013 | 1995 kawasaki GPZ 1100
Can not set screen resolution
Which operating system ?
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Hope this helps.
Jan 16, 2013 | HP Computers & Internet
Laptop screen problem
click start control panel display desktop you can select a different desktop from the drop down list
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Note
hope this helps
Aug 08, 2012 | Dell Studio XPS 1645 Laptop
Is there a setting to fix half screen displayed web pages
right click in the top toolbar (top of screen) you will have an array of options select the menu bar this will add File Edit View Favorites tools and Help to the toolbar select view then from the drop down list select FULL SCREEN
if this does not fix the problem
Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Note
hope this helps
Jul 19, 2012 | Microsoft Computers & Internet
How do I get my vx46w from balck and white to color again?
Hello
Get its Menu, surf through to select the color system. If the color system of your country is NTSC, select it. If it is PAL select it. If your ate not sure about this, select this option to auto, and press enter to save your settings.
Feb 20, 2012 | ViewSonic VX2640w LCD Monitor
THE TV WILL NOT COME ON ITS PLUGED IN AND THE POWER LIGHT SHOWS ITS ON BUT ITS A ORANGE COLOR INSTEAD OF GREEN
Let me know how old is this tv and is it Protron PLTV-32 or any other model.
These info will help me to solve the problem.
Jul 07, 2011 | Protron PLTV-32 Television
Corner of picture is out of focus with colors separated how do i adjust the images
The Philips and Magnavox sets have a way of the anti freeze going cloudy in the green and blue guns. Look (with a pair of sunglasses, while the set is running)) into the lenses, and make sure there is no haziness in the coupling lens (the lens the liquid makes up). This anti freeze keeps the CRT cool since they are run fairly hard, and generate lots of heat.
I have done 2 Philips sets just this week for anti freeze trouble. It should be clear as water, if it is not, that is the trouble. Your trouble could be that the anti freeze levels have dropped, the top of the coupling lens chamber, when the projected image hits the front of the set, appears at bottom of the screen. The image will be out of focus in the area where the anti freeze is gone.
Aug 15, 2010 | Philips 55PW9363 55" Rear Projection...
Everything that is supposed to be black is showing
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Televison & Video
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
