Question about Poly-Wood Polywood Coffee Table
Grease marks on polywood - Poly-Wood Polywood Coffee Table
  • 3 Answers
We have Polywood Furniture that had grease from my son putting his bike chain on it while he was fixing his bike. I just took some mineral spirits with a rag and it wiped right off. Poly-wood is impervious to most all chemcials. I know www.polywood-furniture.com has a page that talks about how to clean your furniture. Still looks brand new!
Posted on Dec 13, 2012
Static electricity from adirondack chairs
depending on the feet there can be some rubber feet you can put on these plastic seat's this will stop the static build up in the plastic, also this can help dont leave the seats out in the sun wash them before use (water will remove the static) also dont were any wooly cottons when you use the seat's as the static from you clothes can build up in the seat. hope this helps. other thing you can do is make a grounding copper strip from the seat to the ground but this would not last long as the chair moving and bending.
Apr 01, 2014 | Poly-Wood Polywood Adirondack Chair...
Motor noise loud squeal
on the motor there should be a grease nipple somewhere locate that un screw it and grease the motor with a grease gun
Sep 02, 2012 | Honeywell QuietCare 17450 Air Purifier
Machine is very noisy especially on silent mode.
Check the fan bearing. Lubricate with spray grease on the spindle but be prepared to replace if no better.
Apr 05, 2012 | Oreck XL Professional Air Purifier
I need a filter for Amcor Ficus Tree Air purifier
If the activated charcoal filter, take your old one apart and trim down a larger on from a competitve machine to fit yours. The same if it is a HEPA filter you want to change as well.
Otherwise metal and plastic filters can be washed. Spray with a grease cutter like 409, which will also lightly etch the metal without reacting with the plastic.
Jan 31, 2012 | Amcor Ficus Tree Air Purifier & Ionizer...
The Fan on my "Fresh
It could be getting clogged up. The lint screen has GOT to be kept clean or the machines fan will pull dust into the machine and it will cake on everything inside, including the fan(will make more sound while running) and can get into the bearings of the fan causing the problems you mention. It may also be a poor electrical connection. If you have ever OILED the motor...you'll have to clean it. It's not meant to have a lot of oil or grease on it.
Jun 10, 2011 | Ecoquest Fresh Air Air Purifier
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
There is a black mark on one side of the purifier plate. does it matter if that is on the top or bottom?
It does not matter whether the mark is on the top or bottom, it will work fine ether way.
Jan 31, 2010 | Ecoquest Fresh Air Air Purifier
I have an Oreck air purifier model (air 4000). The power light is on but the fan will not turn unless I put it on high speed and manually push the fan to give it a jump start for it to start running but...
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
Oct 30, 2009 | Oreck Console Air Purifier
Makes screeching noise
i do apologize for the inconvenience that your having with the noise. usually the screeching noise means something is rubbing up against something inside, or a part that helps the unit run needs to be cleaned or greased. to do the internal the best thing that i can suggest is to take it to a hardware store and see if they can clean it there for you.
Aug 25, 2009 | Bionaire BT40RC Air Purifier
Dirty filter
Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
Apr 05, 2007 | Bionaire BAP825-U Air Purifier
Poly-Wood Polywood Coffee Table Logo
211 people viewed this question
Top Poly-Wood Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Poly-Wood Air Purifier Expert? Answer questions, earn points and help others
