Question about Garden
I have a p28 pioneer, hasnot been used in a few years. I put a new carburator kit in it, now it's over fueling. Gas is coming out of exaust. won't start. It does fire though.
  • 2,239 Answers
You need to do a pressure test on the carb, this will tell you if the inlet needle is leaking, it is also important that the metering lever onto the needle is not set too high, on the metering side of the carb the gasket goes against the carb body first to act as a spacer to the metering diaphram.
Posted on Dec 12, 2012
dontbother10
  • 2220 Answers
SOURCE: Need to rebuild carburator on skilsaw chainsaw
On a different thread:
Oct 22, 2009 – your comment
Got it started by cleaning carburetor but it smokes quite a bit played with 2 screws on side going in all the way and backing out one and half turn still smokes
Oct 22, 2009 – my reply
Tune it until it idles and cuts properly. 1.5 CCW is a good starting point. Tune for performance. 1 turn CCW is as lean as I’d go. Clean air filter, fresh mix, fully warmed up, bar mounted and properly tensioned. HTH
Lou
Posted on Oct 22, 2009
  • 2239 Answers
SOURCE: Model 345 won't start. New
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Posted on Jun 07, 2011
  • 113 Answers
SOURCE: have an old pioneer p38
You need to disassemble the carburetor and check the diaphragm. You need to blow nozzle of carburetor. If the fuel was left in him, now it has remaining traces of oil. You can try to start with a small pump to inject fuel directly into the intake of the air into the carburetor. Of course, the spark has to be here to start. Older chainsaws had a switch and a capacitor, which is very difficult to adjust. Newer chainsaws have electronic ignition, so it is easier for test. Most of carburator has three buttons to adjust. L (low), H (high) for fuel injection at low and high speeds. There is also a minimum (the chain must be stationary if it is well tuned). The chainsaw is set at low rpm throttle with screws ( L ), and its vivacity is set at high speeds ( H screw ). In the beginning is good put both to set at 1.5 turns from full closure. And then, if the chainsaw starts, you can adjust a carburetor work. Careful with adjusting with H due to high speed. Good luck!
Posted on Sep 06, 2011
Gophering
  • 187 Answers
SOURCE: When I stored my pioneer chain saw last year, I
GO TO YOUR LOCAL RURAL KING AND PURCHASE SOME ..."LUCAS GAS TREATMENT FOR CHAINSAWS"... TO CLEAN THE STALE GAS IN YOUR CHAINSAW.
HOPE THIS HELPS!
SOURCE: Chainsaw won't start. Replaced carburetor, fuel lines, fuel filter, ignition module, spark plug. Using new gas and oil. Has good spark but won't pop.
try priming it mite work lol
Posted on Mar 29, 2012
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
When I stored my pioneer chain saw last year, I forgot to empty the fuel from the tank and the carburator. Now it won't start. What should I do? Louis
HOPE THIS HELPS!
Sep 06, 2011 | Homelite Garden
My Subaru backup generator won't start. It started fine last year and ran for about a few days. When I stored it I just shut it off and put it away, didn't add any additives or anything, now it...
you need to take the carburator off and clean it as well as the fuel tank,to start,maybe even a spark plug as well.always use a gas stable additive when you store it,better yet try to get in the habbit of running it once a month
Jun 12, 2011 | Coleman Powermate Subaru 5000W Portable...
My 7-year old 25cc Craftsman line trimmer began surging during use, would bog down when given throttle, then would completely die, became hard-starting, and now doesn't start and run at all. Acts like...
A new fuel filter with new fuel lines and a rebuild kit for the carburetor should do it. You may even be able to get away with just the gasket and diaphragm kit for the carburetor. It is cheaper than the complete rebuild kit if you choose. Run synthetic oil and these things will last a good long while.
May 14, 2011 | Craftsman 25cc Gas Line Trimmer
After primed, mower starts well, runs for about 2-3 seconds then dies
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Oct 02, 2010 | Yard Machines 50 Torque 2in1 22" Push Lawn...
Carburation Getting gas to the carburator but will not stay running without choke on
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
1976 f250 truck sat for 6 yrs the gas has turned orange and smells like varnish this truck has an electric fuel pump i replaced the fuel filter and tried to start it several times with starter fluid ive...
hello, usually when gas sets in carb for a long time it turns into a varnish, you will have to take carb apart and clean all jets out, even the fuel pump may be clogged up, you will probably have to rebuild carb, unless you have access to air line to blow any and all jets, pretty much all passage ways, power jets, in other words you have a carb problem, you may need a new one, unless you have a strong solvent, that will break away any varnish or gum up.
Feb 06, 2010 | 1982 Ford F 250
Would like a print and some info on rebuilding a chevy tbi carburator. This is for a 1989 chevrolet fuel injection TBI carburator. Thanks, Jerry
Here is a real good page on TBI
http://chevythunder.com/gm_throttle_body_injection_pg_1.htm
When you ask for the kit at the part store some list it as a carburator rebuild kit and some list it as a Throttle Body rebuild kit. Not much to rebuild, Clean it put in new gaskets and o-rings. There is two different kits one comes with a new fuel pressure regulator and one does not. Best to check fuel pressure and fuel filter prior to purchasing the kit. Fuel injectors should be tested and cleaned by a shop. I found a carquest auto parts that had the machines to do it and cost me $40 for 2 injectors.
Jan 09, 2010 | 1989 Chevrolet Suburban
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
