Door won't open.
My CD player won't open. There is a piece above the CD holder that doesn't lift high enough to allow the track to roll forward. With the lightest lift manually it will open. The spring seems to have plenty of tension to it. It will close with no problems.
  • Audio Player... Master
  • 1,258 Answers
Hi Walter, this is called the Chucking arm and is made to hold the disc in place when the Pickup assembly is lifted into place. Often times an analysis will show you that the arm is not being lifted due to a lack of grease (Lubrication in the door mechanism) or that the drive parts- motor and a belt are not transferring the energy well enough. I would start with a belt of the correct size and then it may be fixed.
Posted on Dec 13, 2012
  • 13 Answers
SOURCE: Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
use krazy glue to get the arm glued with the cd port or use electrical tape.
Posted on Jul 14, 2009
SOURCE: Denon CD player DCD 920. When using the
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Posted on Oct 14, 2009
SOURCE: I took the disk changer apart to re-cage the
cannot eject the cd from ıts cage
Posted on Nov 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: nad cd541i doesn't always read
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
Posted on May 19, 2011
  • 6771 Answers
SOURCE: CD tray won't open or close on onkyo dx-c606 cd changer.
Yes! it sounds very likely that a small loading belt has stretched, or the loading motor is not working, this is not an easy repair because the gears are timed and synced to work together, if the unit has a loading belt pull tray all the way out and look in the empty tray, may be visable! if you can remove it without taking it apart all the better, have a Tv repair shop size up the belt for replacement.
Posted on May 02, 2012
Why Won"t the sliding door stay open long enough to insert the cd
There is a switch under the carriage that the tray should hit when it opens to stop the motor
Jun 09, 2014 | Audio Players & Recorders
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
ERROR CODE NP AND NOW DOOR WON'T OPEN
Hello first try unplugging the machine for 7 minutes if this doesn't then allow you to open the door then you can manually release the door lock by taking off the dispenser assebly holder (bezel) and pulling on the door lock release cord you will find inside. Also as far as the nP I think the erro your seeing is ND which is no drain in which you can click this link
http://www.fixya.com/support/t340703-maytag_neptune_error_code_nd another tech has posted with pictures on this issue. IF you have any further questions message me back Thanks
Rick
Sep 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
Anyone know how to repair a broken door for the older model Cozy Coupe?!? I have one the door still which is fairly intact except that it is cracked where the hinge is to the point where the door...
If I understand your problem correctly, then I believe all you should have to do is unscrew the yellow roof. It should have screws inside the back two yellow pieces, likely inside the cup holder. Un-screw those and lift up on the roof just enough so that there is enough room for you to re-insert the door into the holes. If your damage isn't too severe, they should still snap right back in. Then just re-screw the roof. Good luck.
Jun 03, 2011 | Little Tikes Cozy Coupe
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
May 19, 2011 | NAD C542 CD Player
Yamaha cdc 555 5 disc cd player
If you trust yourself enough to open the case w/o breaking stuff, then open it up UNPLUGGED, locate the laser lens (small,clear,plastic) gently clean the lens with a swab of lens cleaner for glasses.
Also clean the chrome runners that the laser assembly tracks on.
Jan 16, 2008 | Yamaha CDC-565 5-Disc CD Changer
172 people viewed this question
 Grubhead
Grubhead
