Question about JVC Computers & Internet
Medion MD 30202 TV sound problems
I just got this tv and its not new it vas given to me so i asumed somting was wrong wtih it so evry thing works fine but the sond some time scrablems and turns of the sound and the picture is still on if i put my headphones in the mini jack of the tv the sond is on if a smack the back of the tv is stays on for a min or 2 usualy takes 10 or 15 mins to get rid of this so can anybody help me fix this
  • JVC Master
  • 7,627 Answers
Wrong category
Posted on Dec 14, 2012
adi_techmax
  • 57 Answers
SOURCE: Mid2020
if this is a desktop: Did you check the power supply? try to replace it with a new one
Laptop: Try to run the machine without the battery plugged in....straight with the adapter....If the laptop still restarts...it's a manufacturing defect which should be replaced by the OEM.
Posted on Jan 18, 2008
SOURCE: Medion Mid2020 MD-41060 Switches self off
You don't need to take it all apart to get at the heat sink.
Take the strip off under the display (slides too the left to unlock) remove the keyboard. You will see a metal plate that covers the fan. (the fan is fixed too this plate. Remove the plate and the heat sink is underneath. You will probably find the fins are packed with lint. If you take the heat sink out be careful of the display cable that is bent around it and regrease the cpu when you replace it.
Posted on Feb 05, 2008
SOURCE: No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Posted on Feb 04, 2010
Testimonial: "Thank you for the response - will try this and see if it works"
AnwarH
  • 107 Answers
SOURCE: my dell mini keeps on going on standby after 2-3 min of usage
Go into "Control Panel", sellect "Power Options" and change the "Stand by" settings. Disable Standby , Hibernation, Sleep and Screen turn of settings
Posted on Mar 26, 2010
cirocpatel
  • 524 Answers
SOURCE: cant get any sound on tv
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two separate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video + sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
Adding channels to favorites MEDION TV MD 30727
Usually, there is a limit to the number of channels selectable as favorites.
Apr 17, 2014 | Medion MD 30262 32 in. LCD TV
Medion tv md 30612. Wont turn on. red led only
you have to call thereafter sales support and they will ask you to send it to them, cause mine is doing the same thing at the moment and apparently its the motherboard inside the tv
Mar 21, 2013 | Medion MD 30169 22 in. LCD TV
Hi, I have the Medion LCD-TV model MD 30058 40inch. I cant get a clear picture anymore, there are popping up lines, like there are bad signals. Sometimes the screen goes totally black, and I have to turn...
Medion LCD-TV model MD 30058 40inch is a "troublemaker", the problem you descibe Trond Larsen can probably be solve by replacing a capacitor on the CPU board, costing only NOK10,-
Are you placed in Norway?
Oct 16, 2010 | Medion MD 30262 32 in. LCD TV
I HAVE A MEDION AKOYA P6620 MD97760 NOTEBOOK WHICH I CONNECTED TO A LCD HD DIGITAL EXTERNAL TV WITH A HDMI CABLE AS PER THE INSTRUCTIONS IN THE MANUAL. I GET THE VIDEO PERFECTLY BUT THERE IS NO SOUND....
sound is not transfered through hdmi from a laptop you will need another lead for sound which is a 3.5mm jack to rca / phono the phono plugs in to the red and white sockets on your tv
Sep 23, 2010 | Medion MD-40954 Notebook
I have a TITANIUM Medion MD 8030 XL PC Desktop. I have upgrade the operating system from XP to Windows 7. MY tv/fm tuner card however no longer works in Windows 7. The XP driver for the tv/fm tuner...
Hi Adrian, i have a problem with my Tv turner, the driver for the web dont works, i lose the dvd recovery from my medion titanium 803 is any posibilty tha you can make a copy y share with me, if want i can pay u a fews buck via Paypal. Please send me a mail to leo4everr@gmail.com
Sep 01, 2010 | Medion MD 1804 (MD 1804 / MD 7315) PC...
Dead set,flashing standby led
Have ordered new electrolytics for psu and will overhaul this when parts arrive.
Any further comments thro your site would be welcomed.
Jun 19, 2009 | Medion MD 30262 32 in. LCD TV
Code for remote control Medion MD 4689
The manual of the Medion MD 4689 remote I own states the following codes for Grundig TVs:
008 017 043 091 101 117 135 136 114.
Best wishes from Spain!
Javier
Nov 07, 2008 | Televison & Video
Can not connect my MEDION 8828 MD computor via a HDMI cable to my SAMSUNG ps42q97 hdx 42
use a vga connector. this tv doesn't support pc mode on hdmi. don't forget the 3.5mm stereo jack out fron your sound card to the 3.5mm input(next to vga on tv). you will get 1024x768 res.
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Kim Halliwell
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
